Headlight wiring issue
Old Mar 9, 2021 | 09:45 PM
Afk's Avatar
Afk
Default Headlight wiring issue
OK so I’ve come across a weird deal here. So I have LED light bars wired to the highbeams. They work fine with halogen bulbs in the housings. But any time I attempt to switch out the LEDs in the main housings the light bars will cease to function. I have tried multiple different LED headlight bulbs I have the same issue. Is there some thing I am missing here?
Old Mar 10, 2021 | 02:29 AM
amrg's Avatar
How is the light bar controlled exactly? High beam signal activates a standalone relay which then turns the light bar on?
Old Mar 10, 2021 | 02:48 AM
Afk's Avatar
Afk
I have it wired ground to the battery and positive from the highbeam positive in the pigtail. I even attempted to install a relay which did not solve the problem I tried to use the Highbeam in the pigtail as a switch unit and for some reason still couldn’t get it to work like I said it works fine with halogen bulbs in the housings but every time I put LEDs in the housing the light bar will no longer fire up when connected to the same wiring.
Old Mar 10, 2021 | 04:04 AM
wpage's Avatar
Do yourself a favor and wire it differently.
Run a line from battery to a switch in the cabin and back out to the light bar and to ground.
Old Mar 10, 2021 | 11:22 AM
X2 what he said. Which was the nice way of saying correct your half-azzed wiring.
In many states it is illegal to run a light bar on the road (day or night) so you have committed yourself to an untenable situation. To do what you are trying, you need a relay and I would not bother.
Indskys
Sep 19, 2020 07:54 AM
phawk1969
Nov 15, 2018 11:37 AM
LastLineOfDefense
Feb 6, 2016 03:20 PM
carid
Oct 16, 2014 06:45 AM
motley1987
Oct 6, 2014 06:21 PM
