Headlamps on!
Old Aug 7, 2019 | 11:13 AM
Cohiba54's Avatar
Default Headlamps on!
2009 H3T Alpha/Adventure
I've checked to make sure the light sensor is not obstructed (it isn't) and the instrument cluster is not on during the day but the headlamps are on. Are they suppose to be on the DLR system/circuit? The previous owner installed LED's (I don't like them) I don't see how that would affect the circuit. I checked to see if he wired trigger relay coming off of the DLR circuit to run the LED's, but there's no outward signs of any wiring hacks going on.
I don't think my 2006 H3 ran the headlamps using the DLR circuit may have and I just never noticed.
Old Aug 7, 2019 | 12:21 PM
In 2006 the DLRs were the parking/turn signal lamps. In 2007+ that was changed to the headlights.... always on unless you turn them off after starting and placing in drive.
Old Aug 7, 2019 | 12:22 PM
Cohiba54's Avatar
Thanks Doc
Old Aug 7, 2019 | 12:55 PM
Time to read the Owner's Manual
If you don't have one then download one
https://justgivemethedamnmanual.com/..._hummer_h3.pdf
Old Aug 7, 2019 | 12:57 PM
Cohiba54's Avatar
I would if I had one. Do you know if there's a PDF of it?
Old Aug 7, 2019 | 01:27 PM
Click Tainter's blue link..... that is it.
Old Aug 7, 2019 | 01:30 PM
the link tainter provided is the PDF.
i read some of your other posts you might have an issue on your can2 B-bus line (that one is usually your secondary network for interior things) not allowing proper communication with your BCM. on my H2 the XM satalite radio module was jamming up the network. i disconnected it and the issue went away. so it can be pretty much any module that interfaces with the BCM. a switch a mirror the radio and its components the amp and so forth. look for things that are not working and disconnect them and its associated modules.
Old Aug 7, 2019 | 02:34 PM
Cohiba54's Avatar
got it thanks Doc and thanks Tainter
Old Aug 7, 2019 | 02:36 PM
Cohiba54's Avatar
I'll start check to see if there are any faults, thanks Bronxteck
H2Miami
Feb 9, 2016 01:30 PM
Oakmtnbody
Dec 14, 2014 07:14 AM
dwilton
Dec 15, 2012 09:37 AM
H3sweden
Feb 26, 2011 06:29 PM
LookAgain79
Apr 17, 2008 09:55 PM
