H3 V8 swap
Old Mar 4, 2021 | 03:14 AM
Blackhummerh3v8's Avatar
Default H3 V8 swap
Hi all i finally have the LS 6.0 engine mounted and bolted to the transmission... a few questions for those who have done the same... The 3.7 original engine ran a fuel in and return line to the tank... do i simply remove the return line and block it of...also will i then have to install a pressure regulator or is this already built into the LS engine...
Old Mar 4, 2021 | 10:17 AM
depends on what engine intake / fuel rail combo you used and what year.
my 2003 H2 has a pressure regulator on the fuel rail drivers side front.
Old Mar 4, 2021 | 05:51 PM
wpage's Avatar
Best do some searching.
What you are doing is not common.
Old Mar 4, 2021 | 06:43 PM
Where is the return line?
Chris Mathew
Jun 2, 2020 01:11 PM
Deano
Apr 5, 2019 08:30 PM
Top05
Jun 24, 2016 06:58 AM
ShirtaDay.com
18
May 2, 2011 06:54 PM
t.j.
Mar 18, 2007 12:24 PM
