H3 stuck in the snow c0131/c0110
Old Dec 22, 2022 | 03:35 PM
H3Brookings's Avatar
Default H3 stuck in the snow c0131/c0110
Hi all
I found this forum trying to get answers to my problem. My H3 got stuck in the snow and while trying to plow threw it I lost my power brakes. I have manual firm brake pedal but no power brakes so stopping is very hard. I did get out and into my garage. I crawled under to see if i ripped off any wheel sensors etc. and everything looks great and no issues found. So i ran some codes and got c0131 and c0110. i checked all the fuses and they are ok. Not sure which or if any relays to check. I went to the big plug on the Power brake module and it has power and ground. I can also here it doing something at the round sensor on the right side. Totally lost on what to do next. I cant get it to a dealer because its 250 miles away.
Old Dec 22, 2022 | 05:11 PM
Default more
also H3 drives normal except all the lights on the dash illuminated abs/traction control/brakes and stab system trac fail
Old Dec 22, 2022 | 05:36 PM
Old Dec 22, 2022 | 06:06 PM
is there a component that would make these two codes come on? Is this related to being stuck in the snow as everything was perfectly ok before with no codes for months.
Old Dec 22, 2022 | 07:01 PM
BPMV (Brake Pressure Modulator Valve)
Old Dec 22, 2022 | 09:51 PM
Can the BPMV be bought seperately?
Bricks
Jan 20, 2020 08:01 PM
Widespread Hummer
Jan 16, 2011 07:52 PM
mr300
56
Feb 24, 2010 09:48 AM
joewcob3
Jan 28, 2009 07:04 PM
dot21
Dec 6, 2007 05:24 PM
