H3 stalling when coming to a stop
Old Jul 27, 2024 | 08:17 AM
Thomas wilmoth's Avatar
Default H3 stalling when coming to a stop
I have a 2007 H3 with 115,000 miles on it. I've owned for 9 years. My problem has only occurred a few times since I've owned it and lasts a few days to a couple of weeks then goes away. I did read a thread done in 2019 about an owner with the same problem. I didn't see where he actually found the cause. If anyone has had this stalling problem and knows the cause please reply. I'm thinking it might be a moisture problem but not sure.
Old Jul 29, 2024 | 05:29 AM
Start simple
-Clean MAF (MAF cleaner only)
-Clean throttle body (carb cleaner or TB cleaner)
-Make sure the intake fasteners are tight (they sometimes vibrate loose)
Old Jul 29, 2024 | 09:14 AM
Welcome. I MOVED this out of the H3 FAQ section because this is NOT and FAQ and that sections tells newbs to NOT post in it.
Look at this thread that sums up what to do.... modern day version of the "tune up"............ Acts like it wants to stall/rough idle -No CEL -What To Do:
Old Jul 29, 2024 | 11:21 AM
Thank you. I'll try the recomended procedures you attached. I Apologize for posting in FAQ.
Old Jul 29, 2024 | 04:40 PM
Scan pcm and post ALL DTC's & HDTC's.
Old Jul 30, 2024 | 11:51 PM
Happy Hummer's Avatar
Dont forget to look at the small curvy hose under the intake resonator box. If dry rotted will cause problems.
Change spark plugs and coils with the oem stuff NOT crap chinaezium stuff.
MorrisonAdv
Jan 28, 2024 08:28 AM
Badhummergirl
Dec 27, 2019 10:04 PM
gaswagon95
Mar 25, 2009 01:05 PM
skeeet
Head and Valve Problems.
39
Mar 11, 2008 05:49 PM
