H3 Reduced power mode with locks and window not working
Old Mar 16, 2019 | 05:43 AM
JRugotzke's Avatar
And just like that, it started working again.
Old Mar 17, 2019 | 10:25 AM
WR3NCHE4D's Avatar
You mentioned the battery light came on. Have the alternator checked if the light comes back on. It could have intermittent failure.
Old Mar 23, 2019 | 11:54 AM
Garrettrock's Avatar
Default Same issues resolved
I’ve had the same issue that has since been resolved. I’ve done the batter terminal disconnection and checking all fuses that can relate to this issue but all was good with them. What I did that worked was disconnect the battery, then reconnected it making the car relearn what it needed through the ECM. After that, the windows or power locks for the driver side didn’t work until about 30 minutes later when they worked all of the sudden. It’s like the car was taking its time to fix itself but it did end up working, power windows and power locks now work. I left it running and drove it around a bit and kept trying until the problem was fixed. I don’t know if it’ll be the same for anyone else but it worked for my situation
Old Sep 5, 2021 | 01:42 PM
jcarrol76's Avatar
Default Key
Try putting key in ignition, disconnect battery, touch disconnected cables, turn on lights and turn to start, it will lock your key in, turn off lights, wait 20-30 min reconnect battery tighten post, and your key should start vehicle, then while running use key fob, lock unlock! If all fuses and connections are good, you will have relearned all info!
Old Sep 5, 2021 | 05:59 PM
Old Sep 7, 2021 | 11:11 AM
You dug up this Old Azzed Thread to offer this BS?????? The H3 stores the last 300 ignition cycles, power or no power and ain't gonna relearn jack from what you posted nor dancing around a campfire with animal pelts on your head.
READ: Old Threads/'Necro-Bumping'
jmn444
Mar 19, 2020 10:31 AM
thorg113
Mar 28, 2018 01:38 PM
Nikk Nucleus
Jan 17, 2018 06:20 AM
runamok
Oct 14, 2011 08:50 AM
simian
Feb 12, 2007 07:07 PM
