Super sparkz Coil pack spring replacement
Old Sep 3, 2021 | 09:06 PM
Eurynomestolas's Avatar
Default Super sparkz Coil pack spring replacement
I don’t remember where I saw the link to this guys paypal. but I found it one night and said screw it i am going to see of these things do anything. Well all i can say is wow these make the response of the H3 so much better. The engine doesn’t shake as much either. Keep and mind I also have the PCM of NC so of you are going to get these that could make some difference. They are super easy to install you literally just pop the springs out of the rubber boots and attach the copper piece to the coilpack and then put the boot back on then put it on your spark plug. Also I notice that when removing the springs a few had oil on them. is that normal or does that mean i have a issue somewhere? oh they were $55
Old Sep 7, 2021 | 01:41 PM
Those are the solution to a nonproblem. Kinda cool too.... They should do no harm, but they aren't going to produce a measurable improvement either. Like fancy aftermarket spark plugs..... super duper somekinda brand....., do the same job as the regular ACDelco plugs they stuck in the motor at the factory.
If it makes you feel like you made an improvement then KUDOS!
Old Sep 7, 2021 | 05:43 PM
Copper is not the proper metal to use within the elements for conductivity! I'll stick with my silver springs.
Here's your monthly cleaning guide:
Old Sep 8, 2021 | 10:06 AM
Guess you missed............ they are made of Beryllium copper. Different animal behaviors for different environments.
50Beowulf
Sep 18, 2021 04:19 PM
Sean Gamble
Feb 29, 2020 12:31 AM
mrjohnp
Jan 8, 2014 04:44 AM
Hummer_SG
Oct 19, 2012 11:09 PM
JRider
Aug 20, 2008 08:43 AM
