No passenger windows
Old Mar 27, 2018 | 08:56 PM
thorg113's Avatar
Default No passenger windows
passenger power windows won’t work on a 2006. The power windows and locks work but the windows won’t work at all. The fuse is good already checked that. I just have no idea what could be the issue
Old Mar 28, 2018 | 09:09 AM
Do individual windows work when using their local control (the switch on that door)?
Has your battery died recently?
Do you still have the crappy OEM Battery Terminal Connectors?
Old Mar 28, 2018 | 09:17 AM
thorg113's Avatar
no the individual windows don’t work with their own switch.
Battery was dead yes but I put a charger on it and still couldn’t get the windows to go down
yes the battery terminals are the originals
Old Mar 28, 2018 | 11:00 AM
The OEM Battery Terminal Connectors are complete garbage. The first #1 mod done to every H3 should be to hack them off and replace with a quality aftermarket set like Stingers or your favorite brand.
And.... luck you, since you are probably going to have to disconnect the battery to correct your windows problem, now is the time.
What happens is, your battery goes dead, or looses a consistent connection, and your windows and/or door locks spaz out. The easy fix is to disconnect the battery for a few minutes, and then reattach the cables Neg first. Or, you may have to try and go down the long list of possible fixes.
Do a search, you could find this and a bunch more, common issue:
https://www.hummerforums.com/forum/h...working-14696/
https://www.hummerforums.com/forum/h...r-locks-39258/
Old Mar 28, 2018 | 01:38 PM
thorg113's Avatar
I’ll change those terminals and check out those other forums. Thanks
GorillaH2
24
Mar 24, 2008 06:39 PM
General
31
Feb 17, 2008 09:32 AM
ecpmd19
Feb 16, 2008 06:57 PM
Krista
Jan 21, 2008 11:00 AM
kild1
Feb 2, 2007 06:33 PM
