3 of 4 windows work and no more power locks...
Old Jan 16, 2018 | 12:24 PM
Nikk Nucleus's Avatar
Angry 3 of 4 windows work and no more power locks...
So I just had to get the oil pressure (sending unit)? replaced because I had an oil leak. I went to pick it up and the battery was totally dead. They hooked it up to the charger, tried jumping it once and no, waited 40 seconds and it started right up. I get home, clicked the lock button on my keychain and the dome light came on, but the doors didn't lock. I thought maybe the batteries were dying so I opened the driver side door and hit lock, nothing worked. I then tried to put the windows down and all but the driver side went down. So it kind of works...but not really. What did laser lube do?? Is it just the main window switch? The power locks fuse is fine. I need some ideas!
Old Jan 16, 2018 | 12:35 PM
They disconnected your battery when they changed the oil pressure sensor. ... Or the battery died while sitting...
Disconnect the battery and hook it back up, positive side last.
Common glitch, it can clear itself after some time on occaision.
Do you still have the OEM crappy azzed battery terminal connectors. Look that up while you also SEARCH your original problem, all kinds of reading material.
Old Jan 16, 2018 | 02:09 PM
I disconnected and reconnected the battery, positive terminal last....And still the same problem. And by oem terminals I'm assuming you mean those plastic cover snap on type things ?
Old Jan 16, 2018 | 02:11 PM
Do you need to leave it disconnected for a certain amnt of time?
Old Jan 16, 2018 | 02:51 PM
No. Only a few minutes should be fine. There are a bunch of threads on this topic, some of them have helpful info., others are a bunch of blabber about unrelated stuff. Like this one, it can't stay on focus....
https://www.hummerforums.com/forum/h...working-14696/
Like I said, often times it will correct itself. Drive it and you might find it fine in a day or so.
The OEM Battery Terminal connectors are 100% garbage. Plan on cutting them off and replacing with a quality aftermarket set, like Stingers or your favorite brand. Those OEM connectors are known to be the #1 cause of electrical Gremlins, especially after a battery replacement or disconnect by Bozo repair techs. Once somebody over-tightens, they are done.
Old Jan 16, 2018 | 08:58 PM
WR3NCHE4D's Avatar
This happened to me a few weeks ago. Never did figure it out before it started working again. It took 3 days to work again. This is just a guess. There is a logic board in the master window switch that can kill the power to the locks and drivers window. I think the board gets a signal from the security system. If it's been below freezing the drivers door switch sticks and the security cuts power to the logic board because the security doesn't see the door open and close. Try unbolting the drivers door switch and bringing it indoors to warm up and dry out. Not saying it will work but worth a try. Only the drivers window and door locks use the the logic board.
Old Jan 17, 2018 | 06:20 AM
Carefully pry up the driver door switch panel (no bolts). Disconnect all of the connections wait a few minutes and reconnect all of the connections.
lostsoul77
Nov 27, 2023 09:19 AM
Longwalker83
Feb 16, 2016 05:29 PM
myveryfastgt
27
Nov 4, 2015 04:24 PM
ghawthorn
Dec 13, 2012 12:12 PM
ecpmd19
Feb 16, 2008 06:57 PM
