H3 need help for sizing 20" with 35" tire
Old Feb 16, 2011 | 07:22 PM
  #31
catchmes2000's Avatar
Nice!! would you have the part # of the rim's or the off set... some dealer's tell me i need -10 off set and other tell me i need -35 with a 20x8.5" rim... Now i am confuse on witch one i need...lol
I am going with the 20x12.5x35" nitto trail grappler's same is pick in the first page on black hummer.
Old Feb 17, 2011 | 01:22 AM
  #32
Bullwheel's Avatar
You sure mean +10 or +35 ...
As we know now that even -12 fit ...I would go for +10....especially as it is only 8,5" wide.
Old Feb 17, 2011 | 07:36 AM
  #33
mbone20's Avatar
I'm confused..are the 20x8.5 ok? and whats the best size for a 35inch tire..this offset stuff confuses me.
Old Feb 17, 2011 | 09:22 PM
  #34
bump
Old Feb 18, 2011 | 07:28 PM
  #35
08JJ's Avatar
Thumbs up
Originally Posted by ar_h3
Here is a pic of my 06 with leveling kit 20" xd monsters with 35x12.50 nitto trail grapplers
Awesome
Old Feb 18, 2011 | 10:18 PM
  #36
Bullwheel's Avatar
20x8.5 fits!
+10 offset: Wheel and tire sits more outside...wider track
+35 offset: Wheel and tire sits more inside...smaler track
Offset determines how many mm the mounting surface of your wheel will be out of center...!
Many tire dealers explain it on their webpage.
Tires:
As soon you know what tire you want to go for check their specs (internet). The manufacturer tell you exactly all dimensions...exact diameter....what rim will fit best!
Several tire sizes are cheaper as they are more common....stores buy them in large amounts and can offer them cheaper.
Old Feb 23, 2011 | 01:06 AM
  #37
roughneck1115's Avatar
so what if it is a 20x9 rim with a -12 offset? sorry im horrible with the hole sizing of rims and offset
Old Feb 23, 2011 | 05:34 PM
  #38
mbone20's Avatar
is the 20x8.5 going to look ****ty?!
Old Mar 16, 2011 | 10:22 PM
  #39
Well finaly got one wheel in for a test run it is 20x8.5 wheel with +10 offset and 5" backspacing Now this combo is only good if you are using 35"x12.5 " tire.
They fit perfect the only thing is wen you cut your wheel's all the way it rub's the front mud flap a litle bit you can trim it or leav it it is not that bad but i will trim the top inner corner so that way i will not rip it offf for some reason and beside it is inside you dont see that...
Here a few pick i took to help with look and how mutch it stick out of the fender.. enjoy
Jeff
Old Mar 17, 2011 | 07:36 AM
  #40
mbone20's Avatar
awesome man running the same set up plus a leveling kit, getting installed in 2 weeks.
