H3 help!!!!
H3 help!!!!
So if someone has any info I need help! I was driving my H3 down the highway and all of the sudden I lost power to the wheels and and my engine reved up like I was in neutral and was pushing the gas. I pulled over and put it in park and when I did it made a loud grinding noise and idled down. I turned it off and had it towed home. So Later that day when I got back home I cranked it and when I put it in drive and it just revs up with no power to the wheels and again made a loud grinding noise when I put it in park. I tried it one more time and before I put it in drive I switched to 4 WD High lock then I put it in drive and could drive it in my yard no problem. Does anyone know what this might be?
Could b ewrong I suppose, but my money is on the transfer case encoder motor. That's the exact symptoms I have seen before with my wife's Tahoe. Hint, OEM encoder motor only, or you will be replacing it again.
