H3 Gearbox and other issues
Old May 1, 2021 | 02:46 AM
Kalle's Avatar
Exclamation H3 Gearbox and other issues
Hello all,
I have big broblem in my H3 I was change my rh drive shaft and all went well, no problems. But when I start my engine no lights in 4 wheel control switch it is all the time 4hi lock drive and dash board is traction control fail service 4 wheel drive.. I also lost my driver vindow all door locks and aft brake lights. Obd scanner is clear and I cant get my gear box to neutral. Im totally confuced. Planning to make hard recet, but I am bit scared if lost all computers data eng.controll BCM etc.
Old May 3, 2021 | 08:49 AM
You do not need to disconnect the battery when working on purely mechanical items. There is no "reset" for GM vehicles, they retain the last 300 ignition cycles power or no power.
I am going to assume you are still using the crappy OEM Battery Terminal Connectors? If so, cut them off and replace with a quality aftermarket set like Stingers or your favorite brand. Your driver door window and locks are a common failure when you disconnect the battery and can take care of themselves after several ignition cycles.
Old May 3, 2021 | 08:54 AM
gpcalero's Avatar
I'm surprised you said "crappy" instead of "crappy azzed" lmao
Monk
May 3, 2021 10:14 AM
Kowaiter
24
May 21, 2019 12:23 PM
hakan
Dec 27, 2017 09:26 AM
Autumn Walker
Mar 25, 2010 10:33 PM
Ghost Rider
Apr 18, 2009 06:00 AM
