H3 Engine swap
Old Apr 4, 2019 | 05:37 PM
Deano's Avatar
Default H3 Engine swap
Ok I found a remanufactured engine in a crate. It looks great and I think I’m ready to pull the old one out. Can anyone recommend any steps that I should be taking when I do this swap out. I just wasn’t sure if there was something else I should be aware of. I’ve swapped out engines before in fords that’s it. And that was years ago when it could be done in half a day. Also if I should be changing anything else out. Since I’ve gone this far. Any suggestions would be appreciated
Old Apr 5, 2019 | 08:58 AM
I have a suggestion..... post ALL your H3 questions in the H3 section. I moved this from the HF Help & Suggestion Center section because ... as the sticky thread at the top of that section says...
HF Help & Suggestions Center is for questions on how to use the forum features here.... has zero to do with any vehicle.
Note the vin# of the new motor, you will need to program that into the PCM eventually. While in there look at the motor mounts, might be time for fresh ones.
Good luck.
Usmc5811
New Member Area
Oct 11, 2019 09:10 AM
Deano
Apr 5, 2019 08:30 PM
wifes07H3
Dec 1, 2017 08:36 AM
Cohiba54
Mar 16, 2017 01:24 PM
Lukijoos
Feb 28, 2015 07:12 AM
