H3 ac light blinks and then shuts off. System won’t calibrate.
Old Sep 22, 2020 | 02:23 PM
TechnoSean's Avatar
Battery & charging voltage perfect. Time to check the hvac control module, pull/clean connector contacts.
Shouldn’t both charge voltages be higher? 12.8 while the car is on seems low, no? So does 12.4 when resting. I thought 12.8 resting was more appropriate and mid 13s while charging?
Old Sep 22, 2020 | 02:37 PM
GBCM (Generator Battery Control Module), controls alternator voltage and yours is working like it should.
More info here:
https://www.hummerforums.com/forum/h...m-43179/page2/
https://srs20assets.service-solution.../TL_Sept04.pdf
Old Sep 22, 2020 | 05:41 PM
TechnoSean's Avatar
More info here:
So I had an extra HVAC controller lying around - who doesn't haha. I bought it last year when I was messing with the "one click from cold" problem along with an issue with my blend door actuator. This problem ended up being a severed reference voltage line so I did not need the HVAC controller then. I decided to pop that in today to test but it would not calibrate. I had some 68 ohm resistors around from the last round of issues so I put one in-line with the blue/black wire and then the system would calibrate. AC functions properly now on all blower speeds. I will report back if that changes. Thank you again for the assistance.
Old Sep 22, 2020 | 06:04 PM
I don't have an extra HVAC controller laying around and I never installed a resistor? Mine is still OEM and works perfect to this day.
Old Sep 22, 2020 | 06:21 PM
Curious, what's the production date on your '07? Mine turned 14yrs old, last month (08/06)
Old Sep 23, 2020 | 05:51 PM
TechnoSean's Avatar
[QUOTE=hummerz;377811]Curious, what's the production date on your '07? Mine turned 14yrs old, last month (08/06)[/QUOTE
The AC was working all day today until just now. I am so frustrated. Any other recommendations?
how do I find the production date? It’s not on the sticker anywhere that I can find..
Old Sep 23, 2020 | 06:51 PM
Did you change the battery terminals?
Production date is on the rear of the drivers door jamb.
Old Oct 19, 2020 | 11:38 AM
TechnoSean's Avatar
I finally got around to changing the battery connectors. AC is working consistently now. Yah. Thanks for the help.
our hummer was made in the same month as yours.
Old Oct 20, 2020 | 11:10 AM
Charge the battery completely. If you haven't already, replace the crappy azzed OEM Battery Terminal Connectors with a quality aftermarket set like Stingers.
Todd Maly
Jul 24, 2020 12:21 PM
mpac165
Jun 4, 2016 04:51 PM
jsbihn
Jun 16, 2015 08:58 AM
crazygn
Mar 19, 2011 02:13 PM
HummerGuy
Mar 17, 2007 06:37 PM
