View Poll Results: Speedometer
How to fix
100.00%
Part #
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Speedometer
Old Oct 18, 2020 | 11:47 PM
vsantos2's Avatar
Default Speedometer
Hello, iam New here. I have been having this issues while driving the speedometer will start jumping back and forth around 40-50-60 ml. The speed sensor has been replaced.
Old Oct 19, 2020 | 11:46 AM
what year and model truck do you have the issue with.
Old Oct 19, 2020 | 01:49 PM
Well, it is something with a speedometer. That narrows it down. Probably the space modulator is failing when getting ready for jump to intergalactic pre-launch navigational programming, causing a waiver of magnetic fields near the needle of said speedometer. Add two Tsp Dilitium to the fuel tank, allow to dissolve, then shake. Should be good to go.
Old Oct 20, 2020 | 08:22 AM
vsantos2's Avatar
Default Speedometor
Good morning,
Hummer 2006 H3. Like I said the speedometer will start jumping back and forth not for long but only around 40-50 mph. It doesn't do it all the time. I recently change the transfer case seals and new oil. Transmission oil has been change and filter. Engine was replace a few moths ago and its running good. Except for the jumping speedometer ?. Thanks.
Old Oct 20, 2020 | 08:26 AM
vsantos2's Avatar
Default Speedometer
Doc Olds, Whats Dilitium ?
Old Oct 20, 2020 | 08:42 AM
vsantos2's Avatar
Default Speeddometer
Here is a clip I record while driving. I hop this help. Thanks https://photos.app.goo.gl/FE5Y33pFtcKvztS68
Old Oct 20, 2020 | 09:13 AM
Speedometer gauge stepper motor OR speed sensor in the Tcase maybe?
Old Oct 20, 2020 | 09:54 AM
Dilitium is two molecules of lithium bonded together and is real. Dilithium Crystals, fake TV stuff.
Old Oct 20, 2020 | 09:57 AM
When you installed the T Case Speed Sensor, did it properly seat all the way in? The rubber O ring can get twisted when installing causing it not to seat fully and/or crooked.
Old Oct 20, 2020 | 11:13 AM
vsantos2's Avatar
Default Speedometer
Doc Olds, I will check again on the speed sensor. But I think is install correctly.
TAINTER, Not sure about the gauge stepper motor, since the jumping is only around 40-50 mph.
