Ac hot
Old May 31, 2016 | 04:58 PM
mpac165's Avatar
Banned
Default Ac hot
Yesterday, I turned on my AC for the first time this season; it blew Ice Cold.
Today, I turned the AC on; HOT (on both driver and passenger vents)
Relay issue?
Old Jun 1, 2016 | 07:37 AM
calif phil's Avatar
Is the compressor kicking on? Feel the AC lines while the AC is on. One should be hot and one should be cold. If they are then you could have a blend door issue, if they are not then look into the freon side of the AC system.
Old Jun 4, 2016 | 02:03 PM
mpac165's Avatar
Banned
I tried AC Pro. The lines did not get cold; the ac did not get cold. Was only able to use a half can of ac pro. I am guessing that means there is enough freon in the system?
Blend Door issue?
Driver's Side And Passenger Side Temperature Regulators? --is this the name for these parts?
I saw a few videos on youtube for the blend door; might cost $270 for a brand new one, $100 if I can find a rebuilt or one from a junkyard...
Any tips on what the issue(s) might be, and costs for parts?
'PRECIATE IT!! THANKS!!
Old Jun 4, 2016 | 04:42 PM
calif phil's Avatar
Is your compressor running? If the line didn't get cold you need to concentrate on the compressor/ freon as your problem.
Old Jun 4, 2016 | 04:51 PM
mpac165's Avatar
Banned
The line did not get cold--but, the Compressor is running.
I can hear it turn on, and off.
I found a few youtube videos that have the same problem--happening the same exact way---I had AC--ice cold--used it twice this season--after the second time---both sides (drivers & Passengers) were/are warm. The youtube videos are specifying the blend door, and the drivers and passengers sides temperature regulators(?)
So, at this point, I need to find the exact name and part numbers for those three parts (blend door, drivers side, pass. side temp reg), and buy them, and get to work...
SO, if you have any other ideas of what this might be, and or of you know the exact names and part numbers I am referring to, I would greatly appreciate it...love the H2.
bigwood212
Jun 16, 2006 10:16 PM
bigwood212
May 28, 2006 07:18 PM
Intercooled
Jul 22, 2005 01:35 PM
