Re-Circulate turns AC On!
Old Mar 16, 2007 | 03:41 PM
HummerGuy's Avatar
Default Re-Circulate turns AC On!
We all know that turning the dial to the windshield defogger turns on your AC compressor automatically, but I discovered a few days ago that simply turning on the recirculate button also turns your AC compressor on.
It was 70 the other day and I decided to test my AC. I turned on the AC for a few minutes and it was blowing cold, so I turned the AC off and just let the blower blow. It was still blowing freezing cold air. I said Hmm, the AC is off. This isn't right. SO, I turned off the recirculate button/vent, and then it started blowing warmer air.
I let the air in the car get hot by turning on the heat (it was pretty damn hot in there). I switched the dial to cold air instead of hot, so it was blowing the air from the outside, which was 70+ degrees. As soon as I turned on recirculate, the AC compressor popped on (you could hear it) and the air turned cold REALLY fast. It must have been about 85 degrees inside the car, so I know damn well it was cooling the air on the inside.
Maybe this is why some people get better mileage then others. If I would have known this my entire winter, I would not have used it as much as I did. My windows didn't fog up if I was the only one in the car, so I would keep it on floor and dash vents and recirculate on the cold cold days.
Why does GM do this stupid crap? I understand most people don't know the AC defog's the windows, but that should be a feature you can turn off, or maybe snip a wire on the climate controls so the AC does not come on when you select it. DOH!
Old Mar 16, 2007 | 04:04 PM
dilo2001gt's Avatar
Default RE: Re-Circulate turns AC On!
NO it shuts off when you put it on defogger
Old Mar 16, 2007 | 04:06 PM
dilo2001gt's Avatar
on Toyotas it comes on and clears the windows faster.
Old Mar 16, 2007 | 04:08 PM
HummerGuy's Avatar
ORIGINAL: dilo2001gt
What shut's off, the AC? The AC turns ON when you use the defogger or recirculate. GM does that on most all their cars with the defogger. What crack are you smokin?
Old Mar 16, 2007 | 04:26 PM
NJTEX's Avatar
The compressor turns on in recirculate mode to make sure that the windows do not fog up under certain conditions. This is common in most cars now. A few other brands take it a step further and eventime-outthe recirculation mode after 15 minutes of use.
Old Mar 16, 2007 | 04:30 PM
azz7772's Avatar
i think it is like that on all vehicles i have fords, dodges,and chevs and they all turn onthe compressor defrost.
Old Mar 16, 2007 | 04:48 PM
dilo2001gt's Avatar
on mine recirculate mode it shut off when i put it on defrost
but it will stay on if its on face or feet
Old Mar 16, 2007 | 05:07 PM
HummerGuy's Avatar
Oh OK. Yeah you are right it turns off the recirculate, I thought you meant it turns off the AC.
Hey I know this is off the subject but is your job safe or are you still looking for a new one?
Old Mar 16, 2007 | 11:41 PM
Voodoo's Avatar
ORIGINAL: HummerGuy
Now who's smokin crack.........
Old Mar 17, 2007 | 12:06 PM
HummerMike's Avatar
crack kills.
