H3 2009 Making sound
Old Aug 4, 2018 | 07:24 PM
Bruno Gerardo's Avatar
Default H3 2009 Making sound
not to sure what this sound is
Old Aug 5, 2018 | 02:06 AM
Gomer's Avatar
Could be fan barely hitting on something? Have you tried moving the fan shroud a bit as maybe fan is hitting it? Could maybe water pump or idler pulley but really to me kind of sound like fan is just barely hitting the shroud? (Just a guess) Good luck hope it’s something simple.
Old Aug 5, 2018 | 01:16 PM
WR3NCHE4D's Avatar
Another guess. Sounds like the belt is slipping a little. Check the belt tension. May need a new tensioner. While your in there, remove the belt and check all the pulleys for play and noise. Run the vehicle for a minute to confirm the noise has gone with the belt off. Never seen this on a GM but, could also be a crank pulley. The rubber and the steel no longer adhere and the steel slips on the rubber creating a similar noise.
Old Aug 5, 2018 | 09:42 PM
I sprayed armour on the belt and no more sound. Kinda odd, relaxed the belt and pullies two months ago.
Old Aug 6, 2018 | 07:18 AM
Sounds like the A/C condenser clutch "chirp" before the whole clutch goes dry and then says BOOM.
Only happens when it's wet out or all the time?
Cymru
Dec 13, 2018 10:38 PM
tuesdaytuesday
Oct 16, 2018 07:52 AM
newh2owner
Jul 5, 2018 06:27 PM
2L8IWON
Feb 25, 2012 09:22 AM
MizzouH2
Jan 30, 2010 06:09 PM
