Gage Cluster Mileage
Old May 18, 2026 | 04:47 PM
RKSmith163's Avatar
Default Gage Cluster Mileage
Long story short, the Temperature Gage is erratic in my 2010 Alpha/Offroad with 246K. Measuring the Actual Temperature, it does not fluctuate. Bought a used Gage Cluster and everything worked but the mileage showed 113K. I was under the impression that the mileage was stored in the BCM. Was I incorrect in my assumption?
Old May 18, 2026 | 05:10 PM
The mileage is primarily stored in a memory chip located directly inside the instrument cluster also simultaneously recorded in the BCM.
BCM Syncing: The BCM also retains a record of the vehicle's true mileage. In some models, if you plug in a new cluster, the BCM will transfer the correct mileage to it automatically after a few miles.
Old May 18, 2026 | 06:53 PM
RKSmith163's Avatar
Thank you. I didn't do a test drive after the installation. I just put the detective one back in. Thank you for the information.
H2-SUT
May 18, 2024 10:54 AM
crum55
Jan 31, 2024 12:33 PM
waltham41
Nov 10, 2023 05:42 PM
viperbluelx
Jun 5, 2014 09:38 AM
Mighty455
Jan 5, 2011 04:25 PM
