Fuse #12 Transfer Case Module - Keeps Popping
Old 11-02-2019, 01:27 PM
DATMTN's Avatar
Default Fuse #12 Transfer Case Module - Keeps Popping
2009 Hummer H3 Base - 124k. Checking out fuses and found that the #2 spot for TRANSFER CASE MODULE was burned out. Put new 30 fuse in place but it burned out in a short amount of time. Any suggestions on what might be tripping it? Thanks!
Old 11-02-2019, 02:09 PM
follow the harness down to the transferase and look for shorts they usually happen at parts where the harness rubs on something metal
Old 11-04-2019, 11:42 AM
Check the connector to the T Case module under the truck.
Has it been wet, like in a parked or stuck in a deep puddle for more than a few minuted since you have owned it?
charlie6017
06-11-2019 12:22 PM
h2finallyh2
04-24-2019 07:50 AM
Donnie6983
11-19-2017 12:11 AM
FatJay
04-20-2017 06:36 AM
CWC
06-27-2014 08:11 AM
Quick Reply: Fuse #12 Transfer Case Module - Keeps Popping
