Fuel issue
Old Oct 22, 2020 | 08:15 PM
Christopher h3's Avatar
Default Fuel issue
Have an 09 h3 that won't start . You can hear the fuel pump kick on but won't start but if you spray starting fluid it start only to run until the starting fluid is gone . I've even changed the fuel pump driver module and nothing changed . I've heard it could be the computer but not sure . Anybody else have a similar problem.
Old Oct 22, 2020 | 08:38 PM
Scan and post the codes.
Old Oct 23, 2020 | 06:05 AM
I would start throwing thousands of dollars of parts at it before I scan for trouble codes.
Just kidding, get it scanned.
I understand you can't get it to the parts store with your H3 so you may have to buy a scanner from Harbor Freight/Amazon/Local Auto Parts Store/etc. or borrow one from a buddy.
Post your codes here and/or do a "the Google" search.
Old Oct 23, 2020 | 11:02 AM
Also search "passlock." Might have that issue?
Old Oct 26, 2020 | 01:51 PM
my code are p069e and p0191
Old Oct 26, 2020 | 07:46 PM
You verified battery voltage @ #3 fuse, and same voltage at fpm?
Relay swap 66 & 72, and check your wipers operation.
Oh, another thing to check:
Are you still using the crappy azzed OEM Battery Terminal Connectors?
Daniel Z
May 11, 2020 09:02 AM
Licjhondelacruz
Mar 23, 2019 05:48 PM
jamesb1516
17
Feb 20, 2018 08:49 AM
marsstar102
Feb 29, 2012 06:14 PM
Gymtitan
Dec 26, 2008 10:32 AM
