Front Wheel Bearings
Old Oct 25, 2024 | 06:14 AM
Pslmd1's Avatar
Default Front Wheel Bearings
I just bought a 2006 H3. If failed inspection since it needs left front wheel bearings and parking brake to be fixed. I was told is over $1500 to fix both, “if he can even get the parts”. I addressed the parking brake separately and was told that is something I can try and fix myself (although I am not overly mechanical). He also said the left front quarter panel is completely gone and around the body mounts it is rotted to point he thinks will affect mounts after a year (I’m up north). I was VERY discouraged since truck looks and drives great. Any advice on the left front wheel bearings— that alone is like $750 but I need it to pass inspection.
Old Oct 25, 2024 | 09:11 AM
Let's keep your H3 Tech questions in the ................... H3 Section.
You really need to go to a different shop. H3 hubs are readily available, look on RockAuto for an example. Quality Timken or GM Hubs are just over $210. Cheaper hubs are cheap for a reason. So the "if he can get the parts" is straight up BS.
I have no idea how a rusted fender would ever affect a body mount.
Replacing a Hub unit on an older vehicle from the North can be a challenge due to corrosion. The three bolts won't be an issue, but that Hub will be good and stuck in the Spindle so I would not recommend this as a DIY project for a novice. If you have a capable friend to assist, then OK. There are tricks on removing a stuck hub, but beyond the scope of this response. The shop you are visiting knows you are in a jam (can't pass inspection), that your knowledge on the subject is limited, and you have an old truck which can be a PIA to work on.... they smell cabbage in your wallet. Get more estimates!
Old Oct 25, 2024 | 11:00 AM
Happy Hummer's Avatar
Where ya located? Pics of rust rot? Back safety, park brake?
Old Oct 26, 2024 | 03:02 PM
jin's Avatar
jin
What do you think of these — they are $50 off (Normally $$149) and usually think of MOOG as a decent brand.
Uh
Old Oct 26, 2024 | 07:28 PM
Pslmd1's Avatar
What do people think of the Moog Hub quality and discounted price?
Old Oct 28, 2024 | 09:09 AM
The discounted price feels great until the second time you have to replace hubs. Moog makes OK parts for cars, I am not overly excited about their truck stuff. They will work, the question is how long will they last.
Gavin Costigan
Jan 21, 2024 05:42 PM
Justinh
Apr 14, 2017 07:52 PM
zefrum
May 3, 2011 03:57 PM
cisco
Jul 7, 2008 09:52 AM
jrbnc
Nov 27, 2007 12:38 PM
