Driver’s side leaking water!
Old Dec 30, 2019 | 05:50 PM
Badhummergirl's Avatar
Default Driver’s side leaking water!
Hi all,
I have read posts about the sunroof drains leaking. I have already blown out both the left and right side sunroof drains and my drivers side is STILL LEAKING. What do I do now.
Old Dec 30, 2019 | 07:05 PM
Originally Posted by Badhummergirl
Hi all,
"Already blown"? Do more research and reconnect the drain tubing.
Old Dec 30, 2019 | 07:26 PM
“Blown out” meaning the drain pipes to the sunroof have been cleaned out. 👍
Old Dec 30, 2019 | 07:30 PM
to decipher hummerz suggestion... if compressed air was used to "blow it out" then it might have blown the line off at one of the ends. either at the sunroof or at the firewall.
Old Dec 30, 2019 | 08:09 PM
The mobile shower, all you need now is shampoo and a towel, when it rains.
Old Dec 31, 2019 | 09:29 AM
Using compressed air does NOT clean out a clogged sunroof drain, but may cause the drain line to become disconnected as was mentioned.
You may want to review the linked threads below. Good luck.
Finally, a fix for clogged sunroof drain tubes
H3 Sunroof Drain Tubes
Hoff
Jan 15, 2019 06:34 PM
racin
40
Jan 26, 2018 10:11 PM
mgurgone
Oct 31, 2011 10:16 AM
Mike
Sep 9, 2008 03:47 PM
Trey124
19
Jun 7, 2007 08:21 PM
