Dirty and missing oil
Old Apr 3, 2025 | 05:49 PM
NFS's Avatar
NFS
Default Dirty and missing oil
2007 hummer h3 138k miles
Changed the oil, drove it for around 1000miles, oil is really dark and I was low . I had to add roughly a half a quart . Or little more than half. Is that normal?
or what may be the problem ?
Old Apr 3, 2025 | 08:02 PM
brothapig's Avatar
I think there are a lot of trucks with that oil burn. I've got about that, albeit with more miles. In fact I believe gm considers 1 qt per 2k miles acceptable, even for vehicles under warranty.
I can't really answer the question on it being dirty though. Mine gets darker fairly quickly as well.
If you are really concerned, send in a sample and get it tested.
Old Apr 3, 2025 | 08:23 PM
NFS's Avatar
NFS
thats strange. And where do you send a sample? And what they test it for ?
Old Apr 3, 2025 | 08:47 PM
brothapig's Avatar
Blackstone laboratories is one. $35. They'll test for water, metals, dirt, acids, additives, etc.
Old Apr 4, 2025 | 08:41 AM
What oil and filter did you use? When was the last time you replaced or cleaned your air filter?
My old 07 and my current 09 Alpha did/do not burn any oil. Dirt in the oil is in part a product of your environment. Dusty dirty air gets sucked in and it is the air filter and oil filters' job to remove as much as possible. Cheap filters are cheap for a reason.
Old Apr 15, 2025 | 03:49 AM
wpage's Avatar
Doc points out a often overlooked point. Environment has much to do with overall performance. If junk is entering your combustion chamber thru intake. It will penetrate and foul your lube. Thereby burn and tarnish oil.
Check replace air and clean MAS flow as part of service routines for best practice.
Old Apr 16, 2025 | 03:07 PM
No update on that Dirty Rotten Missing Oil?
NFS
Jun 23, 2023 05:32 PM
Blinker1
Oct 7, 2021 10:13 AM
nchinn
Hummer H1
Jul 28, 2020 03:43 PM
nijoma
Jan 9, 2013 03:32 PM
syphon
Jan 4, 2008 12:20 AM
