Constant Rattle
Old Mar 6, 2020 | 12:07 PM
HumH3Buff's Avatar
Default Constant Rattle
Hello Everyone
this is my 1st post. I have a 2008 H3 3.7 automatic. I’ve had this H3 for almost a month and have been work through some issues (replaced radiator, throttle body clean, MAP clean, brakes..you know small stuff).
i have a rattle that does not fluctuate with the engine RPMs or speed of travel. does it standing still and moving.
anybody ran into this?
check all under plates and wiggled around on everything. Nothing seems loose.
is there emissions or vac situations that could cause this consistent rattling noise?
Old Mar 6, 2020 | 01:45 PM
Happy Hummer's Avatar
Check all of your heat shielding on the exhaust system.
Start under the hood and pull (gently) on the header heat shield. Then go down the whole exhaust.
Old Mar 6, 2020 | 01:51 PM
Welcome to HF.
X2 what Happy Hummer said. Common cause for rattles are pesky heat shields.
Old Mar 6, 2020 | 03:58 PM
X3
Exhaust manifold heat shield needs oversized washers.
Exhaust system heat shields needs new clamps.
Old Mar 6, 2020 | 06:12 PM
HumH3Buff's Avatar
To late to give it a go over. Will do it tomorrow when the sun out.
thank you for the info
Old Mar 13, 2020 | 07:04 PM
HumH3Buff's Avatar
Happy Hummer, thank you!!
Had a couple shields loose.
thank you
Backporch73
Oct 20, 2018 10:36 PM
LandoBash
Sep 7, 2014 12:42 AM
maks671
Apr 13, 2014 07:03 PM
SCEADU
Nov 10, 2012 03:11 PM
Cornercarver82
Oct 22, 2012 12:27 AM
