Cb antenna inatall
Old May 2, 2014 | 03:29 PM
e0308jr's Avatar
Default Cb antenna inatall
Anybody out there install a cb in their hummer H3? I was wondering where you installed the antenna and ran the coax
Old May 4, 2014 | 08:30 PM
TDavis's Avatar
Installed one a few weeks ago... Mounted the antenna on a generic mount between the spare tire and mounting rack. Ran the coax through the rear cabin vent in the door, through the rubber connector between the rear door and cabin between the hinges. Had to remove the rear left side panel, under the carpet to the rear of the front console whee I mounted my CB. Sounds pretty easy, but was a real pain making it look invisible.
Old May 5, 2014 | 05:55 AM
Bunger's Avatar
I have a side cowl mount on the driver's side, just behind the front fender. Ran the coax into the engine compartment, then thru the firewall.
It kind of balances the truck with the OEM radio antenna on one side, the CB antenna on the opposite side.
Size:  112.4 KB Name:  100_2909-1-2.jpg
Size:  20.5 KB Name:  hummer011-1.jpg
Old May 7, 2014 | 02:47 PM
e0308jr's Avatar
Where did you get the mount and antenna from ? I like that
Old May 7, 2014 | 08:04 PM
Bunger's Avatar
It's made by Firestick
Here's their website: CATALOG Main Page (Frame Setup) On the left side, click on "Molded Side Mount"
Do a search, you can get this from many places online. Best price is about $42 for the whole setup.
Old May 7, 2014 | 10:41 PM
After seeing Bungers cowl mount in person many years ago I followed suit on 3 different Hs.
I am also a fan of the balanced look with the AM/FM on one side and the CB on the other.
Old May 8, 2014 | 04:19 AM
e0308jr's Avatar
Ok thanks
Old Dec 15, 2019 | 01:39 PM
esfop319's Avatar
Hey Bunger; I bought the same antenna and want to mount it where you did yours.....How did you get it through the firewall. The only grommet I see is for the hood release cable (which is way too small). Thanks!
Old Dec 16, 2019 | 11:34 AM
You are digging up 5.5 YEAR OLD Threads to ask a question? That is what PMs are for. Please refrain from resurrecting long ago dead threads.
drtom
Apr 20, 2012 10:50 PM
ptcary
Sep 20, 2009 08:56 AM
FUN VEE69
Dec 25, 2008 12:25 PM
SafariHummerH2
Jul 9, 2008 03:40 AM
Hawaiian Hummah
Oct 18, 2007 12:27 PM
