A/C not working
Old Aug 24, 2024 | 08:06 PM
Ranger Tom's Avatar
Default A/C not working
So the guy I bought this from told me he put a new compressor in the car (looks new) but it never worked. I have to pull the wheel well to ohm the clutch still, but what else could I check? (Fuse is good) When you turn the switch for A/C the clutch does not engage. I can't find the pressure switch, I have check the freon level and it is sitting about 35 not running. I am hoping he added oil when he put on the compressor. Thanks
Old Aug 25, 2024 | 02:19 PM
Ranger Tom's Avatar
When I turn the AC switch on it lights up, I checked for voltage at the compressor clutch wire and have not power to engage the clutch. Usually a low pressure switch or something like that is the cause but I can't seem to find one. Any help would be appreciated.
Old Aug 25, 2024 | 02:38 PM
Old Aug 25, 2024 | 07:00 PM
Ranger Tom's Avatar
I cant believe how dumb I am, no it's not fixed. I forgot why I disconnected the compressor in the first place. The ac clutch fuse blows when you try to turn on the ac. So I was going to ohm the clutch to see if it is bad. But I still don't understand why I have no power to the plug when I turn on the ac?
Old Aug 26, 2024 | 11:35 AM
Ranger Tom's Avatar
Today I checked for power at the fuse, no power on either side. Does the power come from the ac switch in the car? I pulled the relay and have power at the relay. I am by myself so I can't start the car and turn on the relay to hear it click, not sure if it works. I did swap relays but still no power to the fuse.
Old Aug 26, 2024 | 12:16 PM
ski.dive's Avatar
I would take it to an a/c specialist.
Old Aug 26, 2024 | 02:03 PM
Ranger Tom's Avatar
Normally I would except I have no seats in it at all, waiting to get them back from the upholstery shop. So I figured I would try and fix it while waiting. I don't know if you have read any of the other post I have written but if I took it to have all these problems fixed by someone else I would have to take out a second mortgage to pay for it.
Old Aug 27, 2024 | 09:23 AM
Ranger Tom's Avatar
All fixed, looking at the fuse box I notice the diode was not sitting like the one for the wipers. Flipped it around and it fit in the slot. I believe that is why my fuse was blowing. Did a relearn on the ac controls. Hooked up my gauges to the ac system and what do you know, empty! The previous owner put in a new compressor but didn't tight the liquid line all the way. Nice and cold now. Thanks for all your help.
clsimmon
Mar 29, 2020 05:03 PM
Jmcneese00
Jul 1, 2019 02:33 PM
H2Miami
Jun 7, 2019 12:12 PM
H2Miami
Sep 25, 2015 04:48 PM
jerms212
Nov 3, 2014 08:39 PM
