Ac not working . Need help to identify issue
Old Jun 2, 2019 | 03:59 PM
H2Miami's Avatar
Default Ac not working . Need help to identify issue
Well here go again .
The Ac decided to stop working now in Summer with temperatures rising the 90 this is a killer
Will appreciate if anyone van help to identify the problem
Compressor is not clicking. There was a slight smell after it stopped
Working.
I test preassure with gauges shows 0 but seems normal since the compressor is not working
Is there a way to bypass the preasure switch
Or directly power the compressor
Any help appreciate
Old Jun 2, 2019 | 09:50 PM
if the smell was a bit electrical coming from the compressor it might have burned out the A/C clutch. you can check it for resistance to see if the coil is still good you can also check to see if it is receiving power. if it is receiving power then again check the clutch for bad wiring or ground or failure.
if the smell was freon then the compressor might have blown a front seal or o-ring in that case look for dye or oil stains.
Old Jun 3, 2019 | 09:18 AM
oceanbrave's Avatar
Had a similar experience 2 years ago, the smell was burning rubber caused by the compressor seizing and the belt slipping on the clutch pulley.
When the Snowflake symbol "ON", the compressor's electrical clutch engages, pressure builds-up and the pressure switch operates, so bypassing the switch won't make the compressor work.
There's a connector mounted on the compressor (accessed from below) which connects the electro-magnetic clutch, if you press the Snowflake button with the engine running you might hear it "click-in"
If there is no pressure with the compressor is running i.e. the clutch has engaged, then there must be a massive leak somewhere.
I think my compressor failure was caused by my local aircon service shop overfilling, Hummers only require 1.6lbs of R134a refrigerant, overfilling puts too much strain on the system. I eneded up replacing everything except the heat exchanger which I flushed out, there was metal debris everywhere!
I've attached some useful diagnostic info on the subject.
Hope you get things sorted.
Old Jun 3, 2019 | 03:15 PM
legerwn's Avatar
If there is no pressure then you have a leak, even with the compressor off there is pressure in the system
Depending on ambient temperature the pressure will be over 80 psi it 80* F or above if the correct amount of refrigerant is still in the system.
Neal
Old Jun 3, 2019 | 03:16 PM
legerwn's Avatar
You'll need to locate the leak and repair it, look for a large spot of oil, when the refrigerant leaks it also carries oil with it.
Neal
Old Jun 3, 2019 | 09:19 PM
H2Miami's Avatar
Thank you all for the replays
I did a vacuum test today and it didn't hold the vacuum. There was not freon on the line
The leak must be kind of big since the vacuum didn't holdi for more than 30 sec
At this point im not sure if the compressor went bad since the clutch wont engage due the lack of preassure
Only oil I see is in between the high and low valves there is a connection and all the line is dirty . Hopefully that would be the issue and not the Evap
I think I will replace the compressor as well , not sure if it is. Worth it to fix the leak put freon to then find out the compressor is bad
For now I will rent a car WITH AC.
I wont be able to touch it till July
Will keep posted
Old Jun 4, 2019 | 04:38 AM
oceanbrave's Avatar
legerwn's advice is good, also you can add UV dye to help find the source of the leak if you can get it without vacuum. Indeed I found the HI and LO pressures sat around 80psi even though the compressor was broken.
Many posts refer to the refrigerant as "Freon" I think this CFC has been banned and replaced by r134a
Few other things:-
  • There are many O-Ring seals in the system, most of mine showed signs of age and contamination, I would replace them all as you can by a bag of these very cheaply.
  • The LO and HI schrader valves are apparently very common issues, these are cheap and quick and easy to replace.
  • The condensor sitting on the front of the radiator is also prone to damage, in fact my new replacement was faulty from the start.
If I could have I would have got a garage to do mine but here in the UK no one would touch a Hummer. The hardest bit was the bottom condensor pipe which took a lot of time and patience.
Just to add there are a lot of useful youtube videos on the subject, well worth watching.
Old Jun 4, 2019 | 07:03 AM
H2Miami's Avatar
Oceanbrave ... Now you mentioned . I would check the front condensor since I was working on the radiator I may have damage it .
This not going to be fun with 90° plus outside
Wish I had a garage
Old Jun 4, 2019 | 07:49 AM
If you see any oil at that union between the high and low fittings, that is where the orifice tube goes. It is possible that the orifice tube got clogged or jammed up which can cause a failure and enough pressure buildup that the o-ring at that joint blows out. The tube is cheap and easy to replace. I'd look close all over the condenser and all lines though as mentioned to see if you see any sort of oil where it might have leaked out. Of course it could very well be that the compressor or compressor clutch just died.
If the compressor grenaded and/or you see a bunch of debris on the orifice tube screen than you probably need to get the entire system professionally flushed out and gone over. You dont want to suck debris into a new compressor and blow it up too.
Old Jun 4, 2019 | 08:02 AM
oceanbrave's Avatar
Its not too expensive to replace, just a bit tricky to access.
As mentioned the hardest part was accessing the lower condenser connector, to do this I removed the short bumper (RHS) and used a socket wrench and then my hand to spin the nut-off.
Also had disconnect the hood's cable restraints, support the hood and remove the cross-member that runs over the top of the radiator, even had to remove the two horns!
The replacement I baought was poor quality and leaked so I ended-up flushing out the old one and putting it back. So I effectively did the job twice, wished I'd bought an ACDelco!
Hope you fix it!
