bubbles in coolant reservoir???
Old Sep 18, 2025 | 06:30 PM
NFS's Avatar
NFS
How a Weak Radiator Cap Causes Overheating
A radiator cap's job is to seal the cooling system and maintain pressure, which significantly raises the boiling point of the coolant. A weak or damaged cap can't hold this pressure.
  • Coolant Boils Prematurely:
  • Without the proper pressure, the coolant in the engine can reach its boiling point sooner than it should, even at normal operating temperatures.
  • Coolant Loss:
  • As the coolant boils, it expands and can be forced out of the system through the overflow tank.
  • Reduced Heat Transfer:
  • When the coolant boils, it becomes less effective at absorbing and transferring heat from the engine.
  • Overheating:
  • The loss of coolant and the reduced efficiency of the remaining coolant lead to rising engine temperatures, causing overheating.
    Symptoms of a Failing Radiator Cap
    • Overheating Engine: The most obvious sign, with the temperature gauge frequently reading high.
  • Coolant Leaks: Puddles under the vehicle or a low coolant level can indicate a leaky cap.
  • Overflowing Coolant Reservoir: Coolant spilling into the overflow tank due to a failing cap.
  • Collapsed Hoses: A faulty cap might create a vacuum, causing radiator hoses to collapse or flatten.
  • Steam from the Engine: Escaping steam or a sweet smell often signals coolant escaping the system due to a bad cap.
What to Do
  • Inspect the Cap: Check the cap's seal for wear, damage, or corrosion.
  • Replace the Cap: If it's old, worn, or shows signs of failure, replace it with a new cap that matches your vehicle's specifications. Replacing a radiator cap is a relatively inexpensive and often effective fix for overheating issues.
if it’s the cap then why when I plug the pressure tester and build 15psi. It start to bubble instantly and the pressure start dropping instantly ? If it’s the cap then it should hold pressure with the pressure tester cap
Old Sep 18, 2025 | 07:14 PM
Happy Hummer's Avatar
That could be a leak in your head gasket. One of the water passages.
Old Sep 19, 2025 | 06:24 AM
NFS's Avatar
NFS
thats what i am thinking too
Old Sep 19, 2025 | 09:23 AM
ski.dive's Avatar
I had the same problem with my CHEVY TAHOE-
* I saw tiny bubbles coming up in the radiator reservoir-It was a bad Head Gasket
I purchased= ACDELCO Cooling System Seal Tablets part # 10-108 on AMAZON
I crushed the tablets and put them in my radiator 4 years ago
-Problem solved-No more overheating problems, it's been 4 years
Old Sep 19, 2025 | 09:40 AM
NFS's Avatar
NFS
that’s awesome I’ll give it a try!
Old Sep 19, 2025 | 10:09 AM
A pin hole leak almost never/rarely hits the ground. It will not drip until the hole gets enlarged. Before that, it oozes very small amounts of coolant every time the system gets pressurized which blows back on hot engine/exhaust parts and burns off. Usually smells and attracts dirt and grime. If it is on the front side behind the Condenser, it would be hard to see.
However, you say no smell so likely not your issue.
Good luck.
Old Sep 19, 2025 | 11:25 AM
ski.dive's Avatar
[QUOTE that’s awesome I’ll give it a try![ /QUOTE]
Make sure you crush the tablets up into a powder.
Drop the powder in the radiator.
Drive it for 30-45 minutes.
Let it cool down and set in overnight.
Drive it again the next day for 30 more minutes.
No more problems since.
*Read the reviews of these tablets on AMAZON
Hopefully it will work for you also.
Old Sep 19, 2025 | 12:01 PM
NFS's Avatar
NFS
[QUOTE [b]that’s awesome I’ll give it a try![ /QUOTE]
I ordered it it’s arriving tomorrow , do you crush 1 tablet ? The pack came with 4
Old Sep 19, 2025 | 12:03 PM
NFS's Avatar
NFS
Good luck.
yes I don’t smell anything and nothing on the ground it’s probably a small crack in the head gasket that passes air thro the coolant way. I’ll try those tablets if they didn’t work I am taking the whole damn engine for a build up lol so we will see
Old Sep 19, 2025 | 12:29 PM
ski.dive's Avatar
I crushed 'all' the tablets into a powder and then I put the powder in the radiator.
Read the reviews on these tablets, from people that have used them.
