bubbles in coolant reservoir???
hey folks, I got 2007 hummer H3 around 135k miles. recently all the sudden I been having bubbles coming from the coolant reservoir and overheating like 220+. and when I drive on it, the coolant in the radiator is low but the reservoir still full. I did a chemical block test for blown head gasket and it came negative, no leak visible anywhere outside, no white smoke from exhaust and no mix coolant with oil. I did a pressure test and it's not holding pressure when I go 15PSI, it immediately start to go down slowly while bubbling coming from the coolant reservoir. I changed the thermostat thinking it's maybe not opening but still the same problem.. anyone knows what's going on? is it a bad head gasket???
thank you
thank you
i checked that and checked the engine oil but when I use the pressure tester as soon as I put air in there or pressure it start to bubble from the reservoir
But if there is a hole wouldn’t it leak coolant?? Because I don’t see any leak! One day I was driving and all the sudden it start to get hot luckily I was close to home so I popped the hood and looked everywhere and I didn’t see anything but noticed air coming from the coolant reservoir .. I don’t know if it’s a head gasket since the chemical test came negative but the pressure test as soon as I pump 15 psi it immediately start to leak air and pressure into the coolant reservoir and bubbles and the pressure start to drop slowly
and I replaced that with brand new one and it still does it . Maybe there is a crack into gasket that the air passes theo to the coolant
How a Weak Radiator Cap Causes Overheating
A radiator cap's job is to seal the cooling system and maintain pressure, which significantly raises the boiling point of the coolant. A weak or damaged cap can't hold this pressure.
What to Do
- Coolant Boils Prematurely:
- Without the proper pressure, the coolant in the engine can reach its boiling point sooner than it should, even at normal operating temperatures.
- Coolant Loss:
- As the coolant boils, it expands and can be forced out of the system through the overflow tank.
- Reduced Heat Transfer:
- When the coolant boils, it becomes less effective at absorbing and transferring heat from the engine.
- Overheating:
- The loss of coolant and the reduced efficiency of the remaining coolant lead to rising engine temperatures, causing overheating.
Symptoms of a Failing Radiator Cap- Overheating Engine: The most obvious sign, with the temperature gauge frequently reading high.
- Coolant Leaks: Puddles under the vehicle or a low coolant level can indicate a leaky cap.
- Overflowing Coolant Reservoir: Coolant spilling into the overflow tank due to a failing cap.
- Collapsed Hoses: A faulty cap might create a vacuum, causing radiator hoses to collapse or flatten.
- Steam from the Engine: Escaping steam or a sweet smell often signals coolant escaping the system due to a bad cap.
What to Do
- Inspect the Cap: Check the cap's seal for wear, damage, or corrosion.
- Replace the Cap: If it's old, worn, or shows signs of failure, replace it with a new cap that matches your vehicle's specifications. Replacing a radiator cap is a relatively inexpensive and often effective fix for overheating issues.
