Brake went to floor
Old May 22, 2023 | 11:09 AM
Latindrift's Avatar
Question Brake went to floor
I have a 2006 Hummer H3 and was driving to work half way there i went to step on brake it went straight to floor. I had to pump brake so the brakes would get hard over and over till i got to work. When i parked brakes still went to floor i turned vehicle off checked brake level which was full and went inside. About 2 hours later i had to go home to get my pick up i jumped in hummer and everything worked fine no brake issues or nothing. only happened that one time. And when it did happen a display on dash said abs traction fault. Any ideas i'm thinking about draining brake fluid and putting new fluid in. I dont think the master cylinder is going bad i hope not. Any help would be welcome.
Old May 22, 2023 | 01:01 PM
Disel's Avatar
abs block electric motor
Old May 22, 2023 | 05:39 PM
Old May 23, 2023 | 03:29 PM
Latindrift's Avatar
Is there an actual part number for that part alone or is it the whole brake valve assembly?
Eurynomestolas
Aug 31, 2021 05:22 PM
odieholtz
Apr 27, 2021 10:47 AM
sns
Jun 1, 2010 07:42 AM
AMG55
Apr 15, 2008 11:32 PM
Sugardaddy
16
Mar 3, 2007 08:09 PM
