Blower Motor not working
Hello! I have a H3 with an I5 and I have had constant issues with my HVAC/blower.
My HVAC started having problems around 2 1/2 years ago and it has been on and off since. I have replaced my HVAC control module, HVAC wiring harness, and blower motor/resister multiple times. I have taken it to a shop before hand and the issue stopped for them. However after taking my car in for a different issue I asked them to address the HVAC problem again. I was told it was my blower and resistor, I replaced them to no avail. I started checking on the forms and one post talked about checking for power to the HVAC control module. I have checked power going into the HVAC control module and it does have power.
Another thing I will mention is that when I turn the speed *** to any position and have the AC button on, it does put Freon into the system. If I drive with recirculation on it will force air through the vents at whatever setting I have it on (hot/cold).
Any help will be greatly appreciated!
(This is my first post on the forum, so if I've done something wrong please let me know!)
I will check them asap and see if I can find out what's wrong.
Already replaced my battery connectors after it left me stranded for a bit will all my friends.
Sorry, can't help with the other/bigger problem you are experiencing; only other HVAC issue that I've had was with the resistor, which was solved with the recall/replacement.
