BCM getting wet
Old May 26, 2021 | 10:33 AM
Mbcreech1's Avatar
Default BCM getting wet
Ok guys need some help. I had a good rain the other day and my BCM went haywire. Took a look with the mech and come to.find out my bcm was wet. Had no wet floor board though. I'm thinking it could be a sunroof drainage issue, but with no wet floorboard I'm not exactly sure. If anyone can give some suggestions that would be great
Old May 26, 2021 | 01:32 PM
When the sunroof drains are plugged (by lack of maintenance), the water leaks from the sunroof tray, onto the headliner, down the A Pillar and behind the passenger kick plate right where the BCM is mounted. Even a little bit of water in the wrong place can short the BCM.
Do the sunroof drain fix posted here to solve the problem from happening again. You can test if the drains work by pouring a cup of water in the tray and see if it drains out onto the ground at the back of the front fender quickly. If it only drips, or takes a long time to drain onto the ground, you need the fix.
Old May 26, 2021 | 01:42 PM
Mbcreech1's Avatar
Doc, can you provide the link to solve?
Old May 26, 2021 | 05:17 PM
Old May 26, 2021 | 05:22 PM
Mbcreech1's Avatar
Ok great guys. Thanks for the solve.
lucamlenti
Dec 13, 2024 10:04 AM
Vmgreen0110
Nov 1, 2020 02:41 PM
FloridaH3t
Hummer H3T
20
Oct 24, 2018 08:54 PM
dognut
May 17, 2017 05:59 PM
Steve.in.Roanoke
Nov 10, 2016 11:15 PM
