Tpms h3
Old May 8, 2021 | 11:36 AM
defcdi2's Avatar
Default Tpms h3
Hello, Im new to this forum and have a question. I just replaced all 4 sensors on my 08 Hummer H3. I went through the calibration
steps as noted in the video. I continue to get the low tire light as well as the SERV TPM. I took it to the dealer and they were useless then went to Discount tire and they couldn't help me either, does anyone have this same problem? I suspect that the Tire Pressure Module is bad, but have no idea where it is located. any help is appreciated.....
Old May 8, 2021 | 01:17 PM
The module(BCM) is located on the passenger side. Does the rke work?
Old May 10, 2021 | 10:17 AM
Did you buy ACDelco OEM TPM sensors or cheap out? Some do not work and/or are not compatible.
Old May 15, 2021 | 06:38 PM
defcdi2's Avatar
Yes the RKE works
Old May 15, 2021 | 07:16 PM
Did you install 315Mhz TPMS SENSORS?
Old May 16, 2021 | 07:06 PM
1eyebandit's Avatar
I had the same problem until I added the spare in the calibration process.
Old May 17, 2021 | 10:07 AM
Except the H3 can only monitor 4 sensors so the 4 on the ground need to be added, forget the spare.
Old May 23, 2021 | 04:13 AM
wpage's Avatar
My solution is to ignore the useless alarm. Just keep your tires inflated properly.
Old May 29, 2021 | 06:32 PM
defcdi2's Avatar
Yes I did
Old May 29, 2021 | 06:33 PM
defcdi2's Avatar
yes i did
