Battery Tender Connection
Old Oct 27, 2020 | 06:59 PM
dcr465's Avatar
Default Battery Tender Connection
So for the easily more electrical knowledgeable than I; I want to connect a BatterTender to my 06 H3's always drained battery. I also have aux lights, GMRS and CB radios connected to the battery. Should I disconnect this "stuff" while recharging or is it safe to leave them off but connected. Yes; I know I need to also search what is draining my battery!!
Thanks in advance
Old Oct 27, 2020 | 08:11 PM
Yes you can charge the battery with everything connected, same result with the alternator.
In the meantime, check for a parasitic draw:
Old Oct 28, 2020 | 02:15 AM
dcr465's Avatar
thanks!!!! Video was also extremely helpful!!!
Old Oct 28, 2020 | 07:55 AM
ozark1's Avatar
Thumbs up
I've had a tender plugged into my H3 for 10 years. I put the short pigtail on the battery..so it just plugs in under the hood. Has never failed to start..and I only drive it once or twice a year. I have one on my Mercedes 450 SL..and on my 26 HP garden tractor...Good products..
Old Oct 28, 2020 | 09:16 AM
Thanks in advance
The more important question is: are you still using the OEM Crappy Azzed Battery Terminal Connectors? If yes, hack them off immediately and replace with a quality aftermarket set like Stingers.
Just like ozark1, I have a BT short plug in pigtail permanently connected to my Battery via my Stinger Terminals and it gets plugged into a 20' BT extension wired to a Battery Tender Plus that sits inside the garage when it is parked in winter on my driveway just outside the door.
ski.dive
Jul 12, 2020 12:07 PM
curleymon
Jan 19, 2019 10:49 AM
DeMopar
16
Mar 11, 2017 06:33 PM
Tech5
Mar 17, 2011 10:32 AM
Theuofmiami
Nov 13, 2010 09:27 PM
