Battery reaching end of life?
Old Dec 19, 2020 | 04:08 PM
Originally Posted by omedus
Thanks guys.
A few years ago I had parasitic draw after
installing aftermarket radio, put back factory radio and new battery.
Dealership thought it was the aftermarket radio, everything else is original-
Does that mean I can never install aftermarket radio I wanted one with the camera
No problem when properly wired!
H3 has Retained Accessory Power (RAP)
which will allow certain features of your vehicle
to continue working for up to 20 minutes after the
ignition key is turned to LOCK.
The radio, front wipers, power windows, and a sunroof
if your vehicle has one, will work when the ignition
key is in ON or ACC. Once the key is turned from
ON to LOCK, these features will continue to work for
up to 20 minutes or until a door is opened.
Old Dec 19, 2020 | 05:09 PM
There are a bunch of I5 H3s that have suffered the parasitic draw problem. Some caused by the rear wiring harness to the license plate light rubbing the chassis = short, poor Battery Terminals Connectors making inconsistent input/output voltage, wet BCMs and/or TCCMs including the harness to them. That is before we even think about aftermarket add-ons.
omedus, when you start a thread asking about your H3....... always: Year; Model (H3s 4); Miles; recent mods and or work done that may impact your issue.
You lost me at short? Yes a short could cause a temporary draw, until the fuse burns, cutting the circuit=no draw.
Parasitic draw will most likely drain a battery in a day or two. Highly recommend to get the battery tested first, since most auto repair/parts facilities will do for FREE! A good read/free check here::> Firestone
dougie
Jun 20, 2020 02:21 PM
curleymon
Jan 19, 2019 10:49 AM
DeMopar
16
Mar 11, 2017 06:33 PM
FUBAR
23
Mar 10, 2011 11:12 AM
Theuofmiami
Nov 13, 2010 09:27 PM
