Dash lights
Old Dec 9, 2020 | 09:18 PM
win717's Avatar
Default Dash lights
Hi everyone, Im new to the forum and a fairy new Hummer h3 owner. I am having an issue with a few things, to start my dash lights randomly don't light up, if I turn the key off and on enough times I will get them to come on. The there are times they work fine, seems to act up if I say move the switch from auto to manual lights. Im not sure if this is related but I have no door chrimes, if i open the door with the key in or have the headlights on and open the door no noise. Any ideas? I was thinking maybe a bad bcm?
Old Dec 9, 2020 | 10:06 PM
Fairy? Has magical powers.
Old Dec 9, 2020 | 10:16 PM
win717's Avatar
Fairy....fairly..been a long day my friend lol
Old Dec 10, 2020 | 07:32 AM
Broken Halo's Avatar
I'd have to say 95% of electrical problems come down to one of three things: Crappy O.E.M. battery terminals, BCM problems and chaffed wires at the rear frame/bumper.
Old Dec 10, 2020 | 08:09 AM
win717's Avatar
Thank you for the reply, this will give me a few things to try.
Old Dec 10, 2020 | 09:08 AM
Happy Hummer's Avatar
I'll add door switches, grounds and main cluster.
Old Dec 10, 2020 | 01:48 PM
I agree with that... possibly 92.37%, but close enough. The BCM issue is highly related to... another 92.37%...... plugged sunroof drains causing a leak into the passenger side cabin A pillar, down onto the BCM and its harness.
Does your H3 have a sunroof, if so, has the carpet been wet. Do you still have the crappy OEM Battery Terminal Connectors?
Old Dec 10, 2020 | 03:44 PM
win717's Avatar
I do have a sunroof and the other day water came in on the driver side and the floor is wet on the drivers side not the pass side. I have to check to see what terminals but pretty sure they are original.
Old Dec 10, 2020 | 04:05 PM
Based on THAT, I'd say it's pretty certain your BCM is the problem source.
Old Dec 10, 2020 | 04:29 PM
win717's Avatar
I thought Id give a little update see what everyone thinks. I checked to see what battery terminals I have and yes I do have the oems, I decided to clean them till I get to the store and pick up new ones, anyways they weren't to bad but after i put them back on now the dash lights wont come on, the drivers side window wont go down and now the door locks don't work...BCM?
