Battery / Battery Terminals...
Old Oct 22, 2021 | 05:49 PM
H32006's Avatar
Default Battery / Battery Terminals...
Hi all, been awhile.
OK, battery seems to be dead. Terminals were all covered in that wonderful white stuff. Took off the terminals, cleaned, etc. and now charging.
OEM battery, looking for something better, etc. but the yellow top, etc. that what once suggested no longer is available for a 2010 H3 Alpha.
Additionally, recall reading to change the terminals. See on here to purchase Stingers.
Now, is there a particular type that needs to purchased (other than to ensure a positive and negative)?
Also, how hard is it to install?
My shop just quoted me for the battery (interstate) $220 (Insterstate).
But we have been having issues with truck. with ABS failure, etc. and wondering if the terminals also need to be replaced, again, how hard is it?
Also, what type of battery is needed for an H3.
Old Oct 22, 2021 | 06:51 PM
I recently replaced my 7yr old Deka battery and got a new 1 with a 10% discount code+free home delivery from NAPA =saved me a gallon of gas.
My '12
Stinger SPT55301 PRO Series Battery Terminals Stinger SPT55301 PRO Series Battery Terminals
are still like new.
Old Oct 22, 2021 | 07:39 PM
Old Oct 22, 2021 | 07:42 PM
H32006's Avatar
My '12 Stinger SPT55301 PRO Series Battery Terminalsare still like new.
Thanks.
How to you use jumper cables with the stingers?
Old Oct 22, 2021 | 07:52 PM
Originally Posted by H32006
Thanks.
Still has 12.5v+on top of my stingers. New coupon from napa above now 15%.Get yourself an east penn battery!
Old Oct 22, 2021 | 08:12 PM
H32006's Avatar
East Penn is the Napa branded battery? Which is this one? NAPA Battery BCI No. 86 690 A Wet?
Also, and yes I am a dolt, switching out terminals do I have to cut the current one off then crimp, etc.?
Old Oct 22, 2021 | 08:45 PM
BAT8486 East Penn manufactured. Cranking Amperage 850A Cold Cranking Amperage 690A
Hack the wires close to the terminals, then strip the insulation far enough to get clean wire inside the stingers, tighten the bolt clamp then seal.
Old Oct 22, 2021 | 08:51 PM
H32006's Avatar
Old Oct 22, 2021 | 10:11 PM
Stingers I purchased 9 years ago-->>> Stinger SPT53502
Seal:
Like this:
chazyrae94
Apr 22, 2020 10:42 AM
curleymon
Jan 19, 2019 10:49 AM
scottH2
Jul 30, 2013 08:47 AM
Tech5
Mar 17, 2011 10:32 AM
Theuofmiami
Nov 13, 2010 09:27 PM
