Backup camera selection & mounting
Old Jan 6, 2020 | 11:17 AM
brothapig's Avatar
Default Backup camera selection & mounting
New to me '07 base H3. Previous owner installed an aftermarket radio with back-up camera capability. Someone at some point removed the camera, but the wires are run to the back of the vehicle.
I would like to add this back in. I've looked at a few cameras, but the selection is vast. Has anyone installed a particular camera that they really like and that worked well for them? Hookup is RCA.
Also, is there a particular mounting location that has worked well? I've seen some that are incorporated with a license plate holder; seems this might be the easiest? The spare tire presents issues for typical locations.
Old Jan 6, 2020 | 03:57 PM
bureau13's Avatar
I've used the one that mounts to the license plate (technically illegal in Florida, but no one has ever hassled me). They're super easy to install, especially if you've already got the wiring, and they're super cheap (at least mine was). They're not great in terms of quality, and they deteriorate over time, so be prepared to replace it. At least, that was my experience. Literally only like 20 bucks though, and it did exactly what it was designed to do.
Old Jan 6, 2020 | 09:40 PM
there is a forum member that makes one you can put on the trailer hitch https://hitchvision.com/shop?olsPage=products
Old Jan 6, 2020 | 10:14 PM
I do not recommend!
Old Jan 7, 2020 | 10:28 AM
Broken Halo's Avatar
[QUOTE=hummerz;368821]I do not recommend!/QUOTE]
How 'bout some LOGIC to go with that OPINION
I've had this setup for 12 years and it's worked perfectly!
Took it one step further and added a second camera facing downward that I can toggle between the two.
Old Jan 8, 2020 | 08:08 AM
The only reason I would not want the hitch camera alone is that I trailer.
When I want to back my rig up to a trailer I can't have a hitch cam and a ball hitch on at the same time.
Broken Halo, that chrome camera cover on the center cap is a nice custom touch!
Old Jan 9, 2020 | 07:46 AM
brothapig's Avatar
Thanks all for the responses. I'm going to try a license plate camera when it arrives this week.
But that spare wheel mounted camera looks awesome! It also avoids what I would consider to be the downsides of a license plate camera (at least on the H3):
  • low viewpoint
  • off center
Both make this not that useful to back up to a trailer. But that spare wheel mount would be perfect. Is this custom, or was this made with available off-the-shelf parts?
Old Jan 9, 2020 | 10:38 AM
This isn't the company I bought from years ago, but looks like the same camera. I bought an extra hub cap (to be able to keep my original), drilled a hole mounted and wired....THAT SIMPLE. The camera has a quick disconnect harness so you can pop it off if you need to remove the spare.CCD universal Car rear view camera Car parking backup camera HD color night vision such solaris corolla k2 car reversing camera | CCTVonlineDIY
Old Jan 20, 2020 | 08:13 AM
Eurynomestolas's Avatar
Mine is located right below the spare tire. It works fine.
ninjarider
Jun 3, 2016 01:09 AM
RBLACKH3
Jun 23, 2012 02:17 AM
RenegadeMicro
Feb 9, 2011 09:05 AM
H34 pleasure
Dec 28, 2007 10:57 AM
Nick119
Jul 6, 2007 03:02 PM
