Backing off torsion keys?
Old Aug 14, 2020 | 06:26 AM
bassackwards's Avatar
Default Backing off torsion keys?
I think the PO has the keys cranked up too much and we want to back them off a little.It is so stiff that it seems like we have no suspension up front.
How should we go about adjusting them properly?
Old Aug 14, 2020 | 10:50 AM
Where the T Bars are set does not make the spring stiffer or softer, remains exactly the same spring rate at all times. H3s were designed to have the bump stops sit on top of the lower A Arm at rest so if your Bump Stops are old and rotted/stiff/cracked they may need to be replaced. Mine is at 23.5" and at rest makes no contact with the bump stops. IMHO riding on rubber stops is just a dumb idea, I'll take extended travel anytime.
The accepted max is 23.5" fender lip to hub center. Anything at or below that is good. Park it on level pavement and check. Use that level surface when/if you make any adjustments.
I would concentrate on making each side the same in case one T Bar settled more than the other. If you do change them, you will need an alignment.
Old Aug 22, 2020 | 03:49 PM
They were turned up to 24" so we backed them down to 23.25" to try that for a while.
The front seems pretty stiff
Old Aug 22, 2020 | 04:01 PM
23.25" is my preferred height
Old Aug 25, 2020 | 02:47 PM
H3Luxembourg's Avatar
second that.
georgethe3rd
Jun 2, 2020 08:45 PM
drewandsteph
Dec 17, 2017 10:43 AM
hwhite
Nov 25, 2013 12:41 AM
Tinseast
Mar 19, 2007 12:19 PM
madmaxmyers
Jul 14, 2006 02:21 AM
