Another Issue
Old Nov 2, 2021 | 01:34 PM
win717's Avatar
Default Another Issue
This one just started happening, I start my hummer at night and the dash lights stay back, i put it in drive the headlights come on but dash lights stay black, if i turn the key off and back on without starting a few tines they will work, im afraid its going to get worse
Old Nov 2, 2021 | 02:26 PM
Have you ever replaced the dash top light sensor?
Old Nov 2, 2021 | 03:31 PM
Do they come on when you manually turn on the marker lights or headlights?
Is the dimmer turned all they way down? Try rolling the dimmer up and down 10 to 15 times. See if that helps.
Old Nov 2, 2021 | 07:24 PM
win717's Avatar
they dont respond when i try manual, timer is all the way up
Old Nov 2, 2021 | 08:07 PM
Pull the switch and clean the switch contacts, connector contacts, or you may need to open it up and clean internal contacts.If you are unable to correct, replace the headlight switch.
LatvjuAvs
Jul 15, 2021 08:32 AM
win717
Dec 21, 2020 10:11 AM
dave23913
Aug 31, 2019 09:07 PM
Patrick Shockley
Dec 21, 2014 06:51 PM
H3 Alpha Dog
Apr 21, 2014 07:02 PM
