Alignment issues
Old Feb 20, 2026 | 08:25 AM
Me 2's Avatar
Default Alignment issues
Just curious if anyone has had front end alignment issues after replacing upper control arms, etc. I also replaced the camber hardware and the tech stated the camber hardware was not working!? I honestly cant see an issue with it but this place I went to has a habit of wanting more money.
For 2006-2010 Hummer H3 Alignment Caster Camber Kit Front 39786VY 2007 2008 2009 - Picture 1 of 3
Old Feb 21, 2026 | 07:12 AM
brothapig's Avatar
Are your pins still there? I had to cut my upper arms out when I replaced mine, and I accidently cut off one of the pins. I had to weld it back on, but it would have been an easy thing to miss. The cam action is all in that pin and cam, and if you don't have them it won't work.
Also, make sure the pin is in the slot for all of your cams; I believe the cam plates can be installed backwards where they won't line up and engage the pin.
Old Feb 21, 2026 | 09:43 AM
Me 2's Avatar
I had similar issues on my h3, had to cut out the tie rod ends, cam bolts to the her control arms, sway bar links, etc. I do have the outer pins still but not the inner ones.
mikabika
Oct 31, 2014 04:01 PM
Andreas_Sweden
Jul 2, 2013 02:29 PM
mr.spooky
Dec 9, 2011 04:40 PM
psych0
May 20, 2009 12:47 PM
General
Jul 3, 2008 04:50 PM
