Alignment 3 times in 3 weeks...
Old May 19, 2009 | 08:54 PM
psych0's Avatar
Default Alignment 3 times in 3 weeks...
Anyone have alignment issues....
2008 with leveling kit and 315/75R16 Kumho Muds...
Pass side went out of alignment 3 times in 3 weeks. I haven't hit any abnormally big potholes or gone off-road... can't understand why...
Old May 19, 2009 | 09:00 PM
twinmill28's Avatar
Default Out of alignment
I'm not a tech, but by the sounds of it, you've got a parts problem. Off the top I'm thinking the rack-n-pinion has an issue. I've got 37K on my H3 and it's holding the same alignment it came out of the factory with. And it's been off roading ALOT. Good luck with it. You'd think the alignment shop would have a clue after seeing it this many times.
Old May 20, 2009 | 11:38 AM
I'd go with incompetent alinement shop, before I went dissin parts. You have to set the alinement, then torque the cam bolts so it won't move. If they stipped your bolts or boogered up your adjusting cams, you are gonna have exactly what you described. A moving target.
Why you askin here? There must be a 500 posts on here telling you you do NOT need a leveling kit, but you got one anyway?
Old May 20, 2009 | 12:47 PM
psych0's Avatar
The drivers side wouldn't crank any higher then a half inch... once I got the leveling kit I got the full 2 inches... and that was by cranking the torsion bar all the way on the drivers side...
drhodgie
Jul 31, 2009 12:29 AM
generh2
Jan 17, 2008 12:26 AM
dot21
20
Sep 12, 2007 09:53 PM
importkiller
36
Apr 1, 2007 02:20 PM
HummerGuy
Oct 26, 2006 02:41 AM
