Is that normal?
Old Feb 23, 2026 | 02:21 PM
NFS's Avatar
NFS
Default Is that normal?
I have 2007 hummer h3 3.7 about 140k miles.
I just rebuilt the engine and replaced crankshaft and installed new crankshaft dowel pin. The car runs fine and has little vibration but I think that vibration is normal. I didn’t drive it in months because it was down so I couldn’t really remember the level of vibration. I was checking everything and I was looking at the harmonic balancer and it look like little bouncing. I installed it and torqued it right but I don’t know if I am seeing things . Does this look normal? Or what can be the problem ?
thank you
File Type: mov
Old Feb 23, 2026 | 02:23 PM
NFS's Avatar
NFS
I huat rebuilt the engine, the car runs fine.
normal vibration. I was looking at the harmonic balancer and it was looking like little bouncing. I installed it and torqued it right but I don’t know if I am seeing things . Does this look normal?
I also attached another video
File Type: mov
Old Feb 23, 2026 | 05:10 PM
what have you done for motor mounts and transmission mount.
Old Feb 23, 2026 | 05:36 PM
NFS's Avatar
NFS
I got a new motor mounts set that came with the transmission mount, I installed the engine o
mounts But not the transmission.
The car idles very smooth but I just start to get paranoid everytime I see the crankshaft balancer
Old Feb 23, 2026 | 09:39 PM
if you got solid mounts or urethane mounts they are usually hard and transmit vibrations. but maybe the balancer got damaged on removal especially if you used a 2 or 3 jaw puller clamped from the belt pully.
the GM puller usually looks like this
Old Feb 24, 2026 | 07:20 AM
NFS's Avatar
NFS
but does it look to you that it’s the actual balancer that’s bad and nothing else serious? Is that usual happen when the balancer start to go bad ? Becuase even when I feel the engine white it’s idling it seem smooth to me . I don’t hear knocking or any other sounds . If it’s the balancer that’s bad I can go to rock auto and order another one and swap it but I just want to make sure before I spend the money and do that. This balancer is the oem original one too
jewjenk
Jan 26, 2023 02:23 PM
mikes h3
17
Apr 6, 2018 02:16 PM
trome92
Aug 21, 2013 07:15 PM
H3OHIO
Aug 13, 2009 10:34 AM
Blaser
Aug 8, 2009 09:14 PM
