aftermarket CAI Box with Airdoc Intake?
Old Aug 10, 2019 | 04:57 PM
  #31
Ordieh's Avatar
Proufound!
Old Aug 12, 2019 | 09:43 AM
  #32
I don't see where you gained performance? You still have 3'' inlet restriction from the air box, removed the resonator, and it appears you used a steel air pipe, which will absorb heat rather easily, and increase the temperature of the air flowing into the throttle body.
Didn't read my last post Aye? The source of the Air Charge, velocity and shape of the intake are far more important than the material out of which it is made. I drive with intake temp indicator on my dash, our intakes run within 2-3F of outside ambient temp. Been recording that for almost 12 years.
The I5s respond very well to an Intake.
Old Aug 12, 2019 | 02:46 PM
  #33
Aye. In order to increase velocity, you need to reduce the size, to the source!
In the pic above, air flows through 3" tubing, then increases to 3-1/2".
That reduces velocity!
A leaf blower is an example of how to increase velocity:
The material used for the Air Charge is important!
Look at how a hot air gun operates, air pulls in and flows across a heating element and out through a nozzle.
Touch the handle or body and it stays cool, however if you touch the nozzle, you will get burned!
The I5 air intake tube is above the exhaust manifold, therefore anything metallic will absorb heat rather easily, and increase the temperature of the air flowing into the throttle body, which defeats the purpose of the CAI.
As I posted above: Increase the amount of cold air intake, to the airbox, then the velocity will increase on exit.
The main thing: keep the air cool!
Old Aug 12, 2019 | 07:43 PM
  #34
Justinh's Avatar
It seems Hummerz and Doc Olds don't even agree on the resonator. How can this be settled. Duel? Someone have a dyno they can borrow?
Old Aug 12, 2019 | 08:24 PM
  #35
Ordieh's Avatar
Just don’t doubt Doc! He’s right more times than Rush Limbaugh.......Damnit
Old Aug 12, 2019 | 08:34 PM
  #36
Above is not about the resonator, it's about CAI.
If you wan't to see the performance loss removing the resonator, check this out:
Old Aug 12, 2019 | 09:14 PM
  #37
Rush Limbaugh is worth $$500million$$ and a Republican, however this is not a political forum.
Old Aug 13, 2019 | 07:53 AM
  #38
Ordieh's Avatar
Typical ———————............knows everything and no sense of humor! Leaf blowers and heat guns?????
Old Aug 13, 2019 | 09:40 AM
  #39
https://www.youtube.com/watch?v=OliY7_Iq9Aw
Doesn't look like an H3. So the relevance would be.... uhm......... zero.
Old Aug 13, 2019 | 09:48 AM
  #40
Your "it is metal therefore it transfers heat" is a common misconception.... just isn't fact. Spend some time testing that assumption and you will be embarrassed you made the comment.
Many other intake manufacturers make steel and aluminum intake pipes, material is not as important as shape and source, not even close.
Velocity and volume is increased by using a smooth inside surface vs the stock accordion couplers and resonator.
