AC Blower fix
Old Sep 12, 2013 | 05:29 PM
  #241
happythree's Avatar
its in the air flow, been that way since cave man days. the h3 just has one weak contact. fix it like others have.
Old Sep 13, 2013 | 12:49 PM
  #242
JoeHummerH306's Avatar
Default Oops
So after finding this post and replacing the resistor and harness w/no a/c still it ended up being a 15.99 a/c relay switch located on the fan itself. Fan is ok, system works now; ended up replacing harness, resistor, and RELAY. System worked after relay was installed. Possibly all 3 were the issue, possibly just the relay. Relay is 15.99 at autozone. Try obtaining parts as Colorado parts to save money. It's the same stuff. Cadillac charged me 112$ for harness and resistor.
Good luck fellow Hummer lovers!
Joe Perkins
Old Sep 13, 2013 | 02:12 PM
  #243
happythree's Avatar
the relay on the fan is the high speed contact for the fan only.it should have run on other speeds,has nothing to do with ac or anything else.
Old Sep 14, 2013 | 08:59 AM
  #244
Default Whatever you say dude
I had already replaced the harness and resister, put it all together, and tested it before I bought the 15.99 relay. After replacing the harness and resister I tested the connector to the fan and had voltage but no fan movement. I took the fan out, spliced some wire to the battery and retested the fan motor and it took off. That left only 1 thing to replace, the relay. After replacing the relay it works fine. Before it was d e a d at all speeds. I'm not an automotive electrical specialist I'm an asst surgeon. By process if elimination it was the only part not changed, and the fan motor definitely worked when energized. The part is 15.99, gasoline is 3.60 a gallon, frustration and scratched up hands/arms are priceless to avoid; I'd recommend changing it while anyone is doing the other 2. Yes, the harness and resister were burnt, especially in right side prong area on both; however, it wasn't till I'd made another trip to Autozone and replaced that cheap part that my hvac system started blowing air again. An ASE certified mechanic told me the relay diagnosis and symptom of only highest speed working; NO speeds worked until all 3 parts were replaced. Was fine one minute, stopped somewhere, turned the truck off, and when I came back the blower was dead at all speeds. No prior issues with any or at any particular settings, just dead. 15.99? Swap it too while you're at it. After changing the 1st 2 parts I'd tested the wire to the fan while relay connector was still connected and it was getting voltage. Did not disconnect relay for that test, when the entire thing was out of the truck, no resistor connected, just straight to the battery and it took off there was only 1 part left to mess with and changing the relay fixed it. It's possible it was just the relay, and it's possible it was the already heat damaged harness and resistor. It's certain that the system didn't work again until all 3 were replaced though, and it's a fact that multiple trips to parts stores suck booty bad; that's why us recommend doing all 3 for 15.99 more- after confirming the fan will respond to voltage.
Old Sep 14, 2013 | 10:36 AM
  #245
happythree's Avatar
ok im glad it works. I guess my 2 service manuals and the downloaded diagram are wrong huh!! thet show the resistors going direct to the motor asnd the relay getting turned on in the last position. it should work without it
just for fun ill pull my relay and see if the low speeds work and report later. im betting 15$ it works!!
don't know how to copy diagram,darn
Old Sep 14, 2013 | 12:39 PM
  #246
Default That's what I didn't try.
Maybe the relay interfered with mine somehow.?.? When I tested the connector to the fan (the 1 w/only 2wires in it) while the fan was still installed I was getting voltage but nothing happened as far as the fan working again. I was just about to replace the fan motor and decided to test it out with application of direct current and it took off. If you're a mechanic or GM employ or know the specifics cool, but on mine as long as the relay was connected it was getting the voltage but something wasn't letting it function. Could have been all 3 parts heat damaged, could have just been the relay. For safe measure I'd recommend swapping them all out if a person is there already. But again I only work on cars as a hobby and usually engine stuff. As far as wiring diagrams,,, I don't even remember the symbols. I'd only picked up a very entry level concept of wiring diagrams from an ASVAB study book in 1996. And that knowledge was never used, except for the test the next day. Mechanical I am! Electrical lol, I am not, but got lucky. What burns the parts out anyway, normal wear and tear, or fan motor pulling amps? I'd like to fix this and forget it 7 more years. Thank you.
Old Sep 15, 2013 | 11:41 AM
  #247
Default Curious
Hey, says ur a sr member? What's the rubber hose for from the fan housing to a port about 9"s away? Something definitely was pulling hard to fry all the connectors; has the underlying reason of burning been determined by anyone? Could the fan be trying to pull too much volts/amps and burning the parts. On mine everything was visually burned including the prongs on the relay I think. The fan motor is 90$ at autozone and 190$ at dealer FYI for fellow hummer owners.. Has anyone on here tried the flexfuel kit for Hummers? If so plz give feedback.
Old Sep 15, 2013 | 12:58 PM
  #248
happythree's Avatar
the hose? for venting/cooling the motor?.
the contact problem has showed up quite a few times but then most h3 never have or had the problem,,,?
I forgot to pull the relay to check op without it
Old Dec 6, 2013 | 05:19 PM
  #249
adamsatl's Avatar
Originally Posted by cdobis
Common Hummer H3 Blower Problem
Has the blower in your hummer quit?
Does the AC light still come on but no air blows out?
Did you notice a burning smell just before the blower stopped working?
You may be a victim of a poor Generous Motors design for controlling blower speeds. With the technology available when Hummers were first made, it seems strange that GM did not implement a PWM system to control the blower speed in Hummers. That system would save energy, not produce heat like a resistor, to control the blower speed. It would have also allowed GM to put a continuously variable speed control on the Hummers for their customers, instead of a four speed switch.
Anyway, they didn’t do it, probably to save a few pennies per Hummer. So those of us who have had to put up with the failure of our blower system, have to dish out big bucks for getting our blowers working again. The repair is not a fix, because IT WILL FAIL again.
Now, you may be able to save those big bucks if you are half way handy with a soldering iron and a Dremel type tool. This may also prevent your blower speed control from failing again.
I assume you know the H3 blower motor and wiring harness is located behind the glove box. Remove glove box to start this project. Remove right end cover to dashboard. Remove blower plug, remove white gang plug, remove black gang plug, THEN remove resistor with connector attached last. Now take resistor and wiring harness to your work bench to start saving more money.
You may have to work to get the resistor removed from the connector as the burnt terminal inside has melted and fused the surrounding plastics together. Keep working at it, rock it back and forth, you will get it apart.
Now, does it look something like this?
Cut around the connector shield on the resistor to allow better access to the terminals. You can cut this with a Dremel type tool or with wire cutters like I did.
Now you can use a file, sandpaper, or a Dremel Type tool to clean and roughen up all the resistor terminals. This will allow the solder to better adhere to the terminals and give you a better connection. We don't want any cold solder joints here.
A
Next, cut the wires behind the connector on the harness so as to get us into some fresh, unburnt wire.
Take note of the wire colors and orientation at this point. We want all wires going back to their original terminal.
Carefully solder each wire to its corresponding terminal, making sure your soldering iron is strong enough and hot enough to make a good clean solder joint on each wire and terminal.
Reinstall the harness back into the vehicle first, and reinstall the resistor last. This will prevent any excess strain and pull on the resistor terminals.
Turn the key on and enjoy your AC blower once again! And it cost you nothing but time. If you made good solder joints, your blower should never fail again!
Good luck!
Craig
I have the same problem... very handy with the soldering iron, but I can't see the pictures you posted... I'll give it a go with just the instructions but wondering if I'm doing something wrong as to why I can't see the photos.
Thanks,
Chris
Old Mar 3, 2014 | 05:21 PM
  #250
mbushnell's Avatar
Hey I am not able to get the pictures to show. Could you send me the instructions in a pdf, doc or docx? Thanks in advance.
