2007 Hummer H3 wont shift from second to third
Old Nov 2, 2019 | 10:23 AM
Chris Catino's Avatar
Default 2007 Hummer H3 wont shift from second to third
2007 hummer h3 122k miles, wont shift from 2nd to 3rd, replaced tranny with a used one and its doing the same exact thing! if there reprogram or something that im missing? 2 tranny's doing the same exact thing? help!
Old Nov 2, 2019 | 02:30 PM
maybe it's an electrical issue with the harness or connector. you would have to connect a scanner that can interface with the transmission to see if she is shifting or if it can activate your shift solenoids.
Old Nov 2, 2019 | 05:33 PM
Seriously, the transmission was not shifting from 2nd to 3rd, so you replaced the transmission?
Old Nov 3, 2019 | 09:48 AM
wpage's Avatar
Ouch, bet that hurt...
Next time ask here first for good resources.
Old Nov 4, 2019 | 11:39 AM
The 2007 H3 Auto Trans is controlled by the PCM. The PCM tells it when to shift and to what gear. You likely have an electrical issue.
Scan it for codes and post whatever codes it may have stored here.
Fito53jr
Aug 14, 2018 08:42 AM
Glassguru
Mar 27, 2018 09:49 AM
blharty
Jul 18, 2016 08:28 AM
Zeppelin
Jun 20, 2016 04:07 PM
rsm688
Nov 6, 2014 05:28 AM
