2007 Hummer H3 slipping in 3rd gear
Old Feb 12, 2022 | 06:16 PM
Andre1981's Avatar
Default 2007 Hummer H3 slipping in 3rd gear
Hi there. I have a 2007 Hummer. I have a bit of a problem with the gearbox. It shifts perfectly fine 1st and 2nd but as soon as it goes into 3rd it just refs up, like there is nothing. It is exactly the same if i manually change the gears. So i dropped the pan and took off the valve body. What i did find is that the 3-2 control valve spring was broken and that control valve was loose. Now whould that broken spring cause the 3rd gear to slip like that, or is it rebuild time for that gearbox.
Any help would be greatly appreciate
Thanks Andre
Old Feb 12, 2022 | 07:05 PM
GreenSpringbok
Jul 2, 2018 10:57 AM
Glassguru
Mar 27, 2018 09:49 AM
203016331
Dec 18, 2014 10:17 AM
fortknox82
Dec 28, 2013 07:33 AM
dizzy
Sep 4, 2007 03:23 PM
