2007 H3 wont fire.
Old Dec 9, 2016 | 10:07 AM
SteveSS's Avatar
Default 2007 H3 wont fire.
It's been a little slow in firing lately, couple of turnovers before it catches. I know about the theft control trick and I've left the key off for 10 minutes or more. Still no fire. Shot some starting fluid down the MAF sensor, nothing.
I did buy the key lock thingy that is supposed to stop the anti theft interference but never installed it. Not sure i can even find it now. It was also extremely cold yesterday. 0 degrees and snowing. Put some Heet in the tank, nothing. Had it out the night before and it was fine.
If anyone has some ideas I'm all ears.
Steve
Old Dec 9, 2016 | 11:56 AM
Happy Hummer's Avatar
Hi,
* Battery connectors
* Battery
* Ground wires
Replace the connectors...Replace the battery...Clean the ground points at the frame and sheet metal throughout the engine bay area.
Old Dec 9, 2016 | 01:52 PM
You mean it is turning over but does not start? Is the security light illuminated on the dash?
The little lock thing
Old Dec 9, 2016 | 02:44 PM
SteveSS's Avatar
Yes the engine is turning over fine.
Yes the security light is on.
The part I have, that I haven't installed is about 5 inches long and has a black and white plug at one end. If I knew what it was called maybe I could look up how to replace it.
Old Dec 11, 2016 | 08:07 PM
Passlock
Old Nov 17, 2019 | 12:07 PM
Aprild's Avatar
Default Hummer h3 2007 anti theft lock 🔐 won’t start
I purchased a by pass module and it worked I drove it shut it off and now it won’t start again.
Old Nov 17, 2019 | 04:35 PM
did the pass lock light come back again? read the instructions maybe it needs a relearn for your bypass module.
Old Nov 17, 2019 | 06:01 PM
It appears you need a double bypass.
Old Nov 17, 2019 | 09:52 PM
Aprild's Avatar
So buy a second one and put that in also?
Humm3r
Apr 5, 2021 01:21 PM
redneckhoosier
Oct 14, 2013 10:05 AM
r.spoonemore
Feb 3, 2013 10:29 AM
TrailerQueenH3
Oct 11, 2012 11:22 AM
Harry007
Apr 25, 2011 04:56 AM
