2007 H3 wont fire.
It's been a little slow in firing lately, couple of turnovers before it catches. I know about the theft control trick and I've left the key off for 10 minutes or more. Still no fire. Shot some starting fluid down the MAF sensor, nothing.
I did buy the key lock thingy that is supposed to stop the anti theft interference but never installed it. Not sure i can even find it now. It was also extremely cold yesterday. 0 degrees and snowing. Put some Heet in the tank, nothing. Had it out the night before and it was fine. If anyone has some ideas I'm all ears. Steve |
Hi,
* Battery connectors * Battery * Ground wires Replace the connectors...Replace the battery...Clean the ground points at the frame and sheet metal throughout the engine bay area. |
You mean it is turning over but does not start? Is the security light illuminated on the dash?
The little lock thing http://repairpal.com/images/managed/...ight_Amber.jpg |
Yes the engine is turning over fine.
Yes the security light is on. The part I have, that I haven't installed is about 5 inches long and has a black and white plug at one end. If I knew what it was called maybe I could look up how to replace it. |
Passlock
Hummer h3 2007 anti theft lock 🔐 won’t start
I purchased a by pass module and it worked I drove it shut it off and now it won’t start again.
did the pass lock light come back again? read the instructions maybe it needs a relearn for your bypass module.
Originally Posted by Aprild
(Post 366836)
So buy a second one and put that in also?
